Author: Subject: Propshaft
WestfieldSEI
posted on 14/9/13 at 04:54 PM Reply With Quote
Propshaft
Hello
I am changing the gearbox in my Westfield from a Type 3 to a Type Nine. I would like to keep the original propshaft but know that I have to change the yoke which fits onto the gearbox due to diameter and spline differences.
I have taken a photo of the existing propshaft below (its the blue one which I think is original Westfield Supplied Item)
Does anyone know if I can simply buy a yoke which will fit straight onto this shaft. I am quite capable of splitting the UJ and rebuilding it myself, just need to know where I can get hold of one.
The other propshaft in the photo came with the Type Nine gearbox so I assume its original Ford Cortina/Escort or similar, but it shows that the UJ yokes are much wider so not an option to use this one.
props 1
props 1
Props 2
Props 2
James
black fingernail
Contributor
Posts 144
Registered 2/7/09
Location devon
Member Is Offline
Photo Archive Go!
Building: finished? scratch built book locost with 1700 puma
posted on 14/9/13 at 05:37 PM Reply With Quote
It looks like you'll have to shorten the larger diameter propshaft.
jacko
posted on 14/9/13 at 07:48 PM Reply With Quote
Mk sell the front section that welds into the prop or at least they did when i got mine
Jacko
