Author: Subject: Compression Tester.....
posted on 14/9/13 at 06:26 PM Reply With Quote
Struggling to get hold of a compression tester and don't really want to buy one.
Is there anybody local (ish) who has a compression tester and would be willing to lend it out for a day or so?
Phil
JC
posted on 14/9/13 at 06:33 PM Reply With Quote
I've got one somewhere, ln5 0nj if that's close enough! Might be at Blyton next week.
Nickp
posted on 14/9/13 at 07:02 PM Reply With Quote
Got one in Wombwell if that's any use?
Shandylegs
posted on 14/9/13 at 07:14 PM Reply With Quote
Phil
I have one you can borrow. Barnsley based but am over in Rotherham area tomorrow.
If it's any use drop me a PM.
Thanks......
stevio73
posted on 14/9/13 at 07:38 PM Reply With Quote
I'm in Selby, you can borrow mine if you like. It is old but bullet proof!
posted on 14/9/13 at 07:54 PM Reply With Quote
Originally posted by Shandylegs
Phil
Thanks......
Just checking but will it fit a motorbike engine? M10 x 1.0
Phil
Shandylegs
posted on 14/9/13 at 09:12 PM Reply With Quote
Phil - Yes I have both fitments.
posted on 15/9/13 at 07:03 AM Reply With Quote
Thanks for all the offers guys, much appreciated.
Shandylegs, you have U2U......
Phil
posted on 15/9/13 at 12:05 PM Reply With Quote
Nickp, you have U2U
Phil
posted on 19/9/13 at 07:41 PM Reply With Quote
Still looking for a compression tester that has a fitting with screw in thread of M10 x 1.0
A few people have the 14mm & 18mm but not the 10mm....
Anyone??......
Phil
Volvorsport
posted on 19/9/13 at 08:01 PM Reply With Quote
Ill have a look at weekend .. i dont think it has tho...
www.dbsmotorsport.co.uk
getting dirty under a bus
View User's Profile Visit User's Homepage View All Posts By User U2U Member   Volvorsport 's Aim
40inches
posted on 20/9/13 at 08:01 AM Reply With Quote
I have an adaptor I made from a 10mm plug, it extends the adaptor 170mm. You are welcome to borrow it.
posted on 21/9/13 at 06:35 PM Reply With Quote
Is it a 14mm - 10mm adapter? If so, could you U2U me your address and I'll arrange a suitable time to collect.
Phil
40inches
posted on 21/9/13 at 08:02 PM Reply With Quote
Phil
Yes, as photo. It's a 10mm plug and !8mm adaptor joined with a length of tubing araldited together. I have used it twice with no problem. Just needs tightening finger tight.
matt_gsxr
posted on 21/9/13 at 08:37 PM Reply With Quote
I think I used an adapter from a colortune kit. Not 100% sure.
It wasn't expensive (not worth posting around).
View User's Profile Visit User's Homepage View All Posts By User U2U Member   matt_gsxr 's Aim
posted on 21/9/13 at 08:57 PM Reply With Quote
I discovered because of the larger volume before the one way valve a long adaptor gives lower readings, ie the adaptor volume lowers the compression ratio.
[I] What use our work, Bennet, if we cannot care for those we love? .
40inches
posted on 21/9/13 at 10:23 PM Reply With Quote
This is true bt, but I found it OK for comparative readings.
Volvorsport
posted on 21/9/13 at 10:44 PM Reply With Quote
nah , no 10mm adaptor unfortunately...
SausageArm
posted on 21/9/13 at 11:21 PM Reply With Quote
Screwfix sell them for 20 quid, with 3 or 4 different adaptors, i've used it on my ZX10R engine a few times.
posted on 22/9/13 at 07:40 AM Reply With Quote
Yest the aren't expensive ISTR mine was under 10 but only 14mm & 18mm and that was about 4 years ago but allowing VAT increase and inflation since then 20 on eBay should still get a decent one with a selection adaptors.
