Author: Subject: Shrinking a pipe end
jacko
posted on 27/9/13 at 07:03 PM Reply With Quote
A mate of mine asked me if i could shrink the end of a piece of brass pipe to fit in his cornet and to his mouth piece
what would i need to do this tool wise
jacko
Dingz
posted on 27/9/13 at 07:28 PM Reply With Quote
Depends on the diameter but a Locost way would be to find a local hydraulic hose company (Pirtek?) and see if their smallest fitting crimplng/swaging machine would do it, probably need 2 tries to help eliminate the die marks.
went on and on.
Phil.J
posted on 27/9/13 at 07:31 PM Reply With Quote
I'd turn a small reducer out of a piece of brass bar and solder it on. If done carefully it will be virtually undetectable.
owelly
posted on 27/9/13 at 07:33 PM Reply With Quote
It needs to be perfectly round so would need to be pressed between dies or rolled. If he's wanting to use a trumpet mouthpiece in his cornet then you can buy an adaptor.
http://www.ppcmag.co.uk
jacko
posted on 27/9/13 at 08:03 PM Reply With Quote
Thinking about it he would be better off getting the pipe the small end size and stretching the other end
Thanks for your comments/ idea's
Jacko
