Author: Subject: Marking steel for cutting with a plasma cutter
jacko
posted on 3/10/13 at 05:18 PM Reply With Quote
Hi all what type of marker do people use to mark steel for cutting with a plasma cutter
thanks
jacko
Minicooper
posted on 3/10/13 at 05:32 PM Reply With Quote
I use these for metal marking
http://waltersandwalters.co.uk/Marking-Metal-Steel-Markers/edding-2000-ink-marker-pens
theprisioner
posted on 3/10/13 at 06:50 PM Reply With Quote
White paint markers:
ebay:310759654454
http://sylvabuild.blogspot.com/
http://austin7special.blogspot.co.uk/
davev8app
posted on 3/10/13 at 09:35 PM Reply With Quote
French Chalk 10 Flat Sticks Welding Engineers Fixings
neilp1
posted on 4/10/13 at 08:18 AM Reply With Quote
^^ what he said ^^ french chalk
file on side down to give you a nice fine line.
carlknight1982
posted on 4/10/13 at 10:27 AM Reply With Quote
French chalk
Logic will get you from a A to B
Imagination will take you everywhere.
907
posted on 4/10/13 at 11:05 AM Reply With Quote
I mostly use scribers in one form or another.
Scriber & rule, dividers, trammels, etc.
If you cut to the side of the line so that the line just shows after the cut
then you still have a line to grind (flap disc) to when you clean up the cut edge.
With other methods the line disappears with the heat from the cut.
HTH
Paul G
neilp1
posted on 4/10/13 at 11:49 AM Reply With Quote
Problem with scriber is seeing the line with dark lenses.
We always use french chalk and then centre pop line at work.
Uphill Racer
posted on 11/10/13 at 10:51 PM Reply With Quote
Or you could tack some scrap together and do this.
[URL=http://i72.photobucket.com/albums/i187/uphill-racer/plasma1.mp4][/UR L]
[Edited on 11/10/13 by Uphill Racer]
