Author: Subject: Oil Breather Hose
ChrisJ15
posted on 6/10/13 at 10:40 AM Reply With Quote
Oil Breather Hose
I need to add a catch tank and need to connect from the vent on my Duratec block as well as a take-off from the rocker cover.
What tubing should I use? Silicon hose seems a bit extravagant for the relatively long runs required.
40inches
posted on 6/10/13 at 11:31 AM Reply With Quote
8mm bore, black silicon,£3.48 per metre, free postage used them for all my hoses. AutoSiliconeHoses Vacuum Hose Pipe Silicone - Select Your Colour &' Length - Air
ChrisJ15
posted on 6/10/13 at 11:45 AM Reply With Quote
Prefect - Thanks!
big-vee-twin
posted on 6/10/13 at 12:24 PM Reply With Quote
Make sure you remove the ball bearing and spring from the Crank case breather too
http://www.triangleltd.com
ChrisJ15
posted on 6/10/13 at 12:54 PM Reply With Quote
I'd seen something on that but then read something after that seemed to contradict it.
big-vee-twin
posted on 6/10/13 at 04:52 PM Reply With Quote
The valve will not open due to not having a vacuum sucking on it, so the crank may over pressure.
Thatcher
posted on 6/1/14 at 09:13 PM Reply With Quote
Duratec breather valve.
Hi big vee twin,
Could you explain how to remove said valve from breather cover and how to remove the ball and spring from inside,
[Edited on 6/1/14 by Thatcher]
nickm
posted on 7/1/14 at 07:46 PM Reply With Quote
Hi Chris
Back to the original question i used silicone on the J15 but only because it looks nice and matched the other silicone runs ! on my Tiger i had clear pvc cheap as chips and you can see that its working and far more pliable to link up etc. Youll probably end up with more condensation in the tank than oil.
Nick M
Your making progress then ?
