Author: Subject: Track rod ends that bend
Benzine
posted on 20/10/13 at 08:40 PM Reply With Quote
I need clearance, Clarence. I'm after some TREs that have a downward bend in them such as these:
Only things I can find so far are stateside, anyone know of any common cars in the UK that have a similar TRE?
adithorp
posted on 20/10/13 at 08:49 PM Reply With Quote
Can't think of any that bend down. There's a few that bend side ways.
http://jpsc.org.uk/forum/
Benzine
posted on 20/10/13 at 08:57 PM Reply With Quote
I'll have to double check clearance tomorrow, but sideways ones might possibly work too
chaddy44
posted on 20/10/13 at 09:06 PM Reply With Quote
try 07/08 fiesta onwards they have a bend in them as do renault laguna
posted on 20/10/13 at 09:17 PM Reply With Quote
Some Rover ones bend sideways
[Edited on 20/10/13 by britishtrident]
Benzine
posted on 20/10/13 at 09:46 PM Reply With Quote
Just to add, they'd have to bend like this:
(if that makes any sense!)
theprisioner
posted on 20/10/13 at 10:01 PM Reply With Quote
Stupid question. Can you not put one end in water (the bit with the ball etc) then heat the other part with Oxyacetylene and make it any shape you want. With a bit of skill you might be able to make two of them (mirror image I assume).
http://sylvabuild.blogspot.com/
http://austin7special.blogspot.co.uk/
loggyboy
posted on 20/10/13 at 10:33 PM Reply With Quote
Citroen c2 and c3, but again its a sideways bend.
Mistral Motorsport
posted on 21/10/13 at 04:14 AM Reply With Quote
Because they have to carry a bending moment bent track rod ends have to be a much beefier section than straight ones.
Wheels244
posted on 21/10/13 at 04:21 PM Reply With Quote
I've got these that you can have to trial fit or mess about with if it would help - they're knackered but would be ok for checking fitment without going to the expense of buying any.
They're off a SEAT Alhambra. I could pop them in the post for you.
[URL=http://smg.photobucket.com/user/wheels244/media/SEAT/SAArms.jpg.html][ /URL]
Benzine
posted on 21/10/13 at 05:54 PM Reply With Quote
Thanks a lot for the offer, but they don't bend the way I need them to (see my badly drawn diagram)
The C2/C3 might be promising. I'm off to the scrapyard tomorrow to see if they have any in
