Author: Subject: bec gear connection
jimhammer
posted on 30/10/13 at 04:51 PM Reply With Quote
bec gear connection
Wondered if I cut out the middle (bit between the cable connection and the gearbox connection approx 1" and then joined the 2 pieces together presuming you can weld them. Would it reduce the amount of movement on the gearstick to change gear and increase the 'spring back' on the gearstick? If so is there anyone on here who could carry out the work?
Thanks.
doobrychat
posted on 30/10/13 at 05:13 PM Reply With Quote
try the gearstick end pivot..
jimhammer
posted on 30/10/13 at 05:21 PM Reply With Quote
That was done by 'Pathfinder' (think that was his u/n) and can't see how I can improve that.
40inches
posted on 30/10/13 at 05:27 PM Reply With Quote
I used a pit bike gear lever off ebay, about a fiver, and drilled a series of holes in the lever.
Shiny Gearlever
Shiny Gearlever
jimhammer
posted on 30/10/13 at 05:38 PM Reply With Quote
That sounds ideal, is the size of the connection on the gearbox standard across most bikes (R1) so that this should fit:
http://www.ebay.co.uk/itm/GEAR-LEVER-UNIVERSAL-CHROME-PEDAL-QUAD-PIT-DIRT-BIKE-50CC-250CC-/271257170088?pt=UK_Motorcycle_Parts&hash=item3f282ff0a8
40inches
posted on 30/10/13 at 06:14 PM Reply With Quote
This is the one I used. ebay The lever is flat, so easier to drill.
Most spindles seem to be 10mm diameter, so should fit. You could check yours before you order
jimhammer
posted on 30/10/13 at 09:02 PM Reply With Quote
Thanks, much appreciate your help.
renetom
posted on 31/10/13 at 09:11 AM Reply With Quote
Hi
This is what we did on our R1
paddle gear change
paddle gear change
nice & free linkage which returns nicely
unlike the drag on a cable.
Good luck.
