Author: Subject: In tank fuel pump + swirl pot
sky
posted on 13/11/13 at 08:10 AM Reply With Quote
Hi everyone,
My ZX-12R Striker has the original Kawasaki in-tank fuel pump and haven't the return line from the injectors.
Now, I want to add a fuel swirl pot to prevent fuel surge.
There is a simple way to realize it without adding a return line and a fuel pressure regulator?
In my mind there are only two options: move the original fuel pump from the tank to the swirl pot and to use a low pressure pump as lifter between the tank and the pot (I dont'like very much to modify the fuel tank)
OR let the original ZX-12R pump in tank and use it as a lifter to the swirl pot where I've to add inside ANOTHER stock ZX-12R pump, if there is enough room.
Regards.
Twin40
posted on 13/11/13 at 09:19 AM Reply With Quote
Go with your first option mate, put the high pressure pump into the swirl pot and get yourself a lifter pump for the tank.
Sorted!
sky
posted on 13/11/13 at 10:01 AM Reply With Quote
Yes, I understand it's conceptually the simplest way, but I really wouldn't modify my fuel tank.
The second option would work?
Twin40
posted on 13/11/13 at 12:00 PM Reply With Quote
Its something i'm planning to do on mine, doesn't require a tank modification.
Simply remove the orginal pump and replace with a plate adapter like this:
then hook that to the low pressure pump, which then feeds the new swirl pot/high pressure pump setup.
You may have problems running a high pressure pump to another high pressure pump. I'm not 100% sure though. Maybe someone else can confirm?
mark chandler
posted on 13/11/13 at 03:09 PM Reply With Quote
You will need a return on the swirl pot or it will empty itself as the pumps caviate introducing air which will gradually displace the fuel in the pot.
