Author: Subject: 2004 Audi A3 3.2 - Electrical Problem
wombat
posted on 13/11/13 at 11:13 AM Reply With Quote
Morning,
Mate of mine (rebuilding a Series11 Landy and will be registering on here soon) has an Audi with a small electrical fault.
The rad fan is running continually, soon as ignition is switched on the fan runs and continues when car is switched off (not sure how long for 10-15mins prob).
Any Audi experts about ??
posted on 13/11/13 at 12:17 PM Reply With Quote
On most modern cars if the engine management runs a test program at start up if detects an out of range reading from one of the temperature sensors it will turn the fan on.
It could also be caused by the AC
Better to buy a diagnostic scanner or dongle+software that has VAG special functions to do a proper check rather than change random components blindly.
austin man
posted on 13/11/13 at 07:40 PM Reply With Quote
temp sensor or rad switch in rad
snakebelly
posted on 13/11/13 at 07:57 PM Reply With Quote
Wot he said!
posted on 13/11/13 at 08:39 PM Reply With Quote
Once had a similar problem with a Passat that was caused by water getting into the fusebox causing corrosion to build up on the printed circuits and short out whennthe fan operated. Bodged it up as a temporary measure by wiring the fan up independently of the fuse box .
v8james
posted on 14/11/13 at 02:42 PM Reply With Quote
My son had this problem on his Golf, fixed it with a new coolant temp sensor.
