Author: Subject: My Xmas 2013 Clearout
yellowcab
posted on 19/11/13 at 08:45 PM Reply With Quote
Round up, round up, get your Xmas goodies here lol
All prices are collection only from LE9 Leicestershire, unless worthwise stated, I will need to get a quote from a courier for certain stuff.
2000w thermostatic electric slimline radiator, used in our conservatory for about 2 weeks whilst we had no boiler, ideal for garage or workshop in these winter months cost £99, would like £50 for it
Ford Sierra front drilled & grooved, PCD 4x108, vented brake discs, no lip, no hairline cracks, 240mm x 24mm thick - £25
Ford Sierra front calipers painted in red, with EBC redstuff pads with about half life left, good working condition, seals & nipples all good - only available as i've upgraded to Wilwoods - £25
Westfield 14k tachometer, 3.5inch, as photographed - £35 delivered
Racetech Mechanical Oil Pressure & Water Temperature gauge, 52mm - SOLD
http://www.demon-tweeks.co.uk/motorsport/gauges-auxiliary/racetech-oil-pressure-water-temperature-dual-gauge
Braided brake hoses, as new - only replaced them as changed over to Wilwoods & also needed varying lengths, these are all around 17-18inches long- SOLD
6.5J x 15" Team Dynamic 100+, 6 spokes, Black, Multistud, 4x108 & 4x100 (i think), et38, as photographed, 16kg per wheel & tyre combo, spiggot rings included
2x 195/50/15 Toyo R1Rs, Dot: 2312, done less than 100 miles, no track days, 7mm tread at least - cost me £200 delivered for tyres alone
2x 195/50/15 Toyo R888, GG Compound, Dot: 1607, roughly 3mm left on them
Please evaluate photos for yourself, not hiding anything - would like £250 for these
6J x 15" Ford Focus MK1 alloy wheels (I think), PCD 4x108, ET40, going to say alloys only as the tyres are bad, but good enough for some build wheels to get them rolling, just want £40 for the set of wheels & tyres
Caterham exhaust can heat shield in black, 26inches long, 5.5inches in diameter - £30
Standard Suzuki Hayabusa clutch master cylinder (0.600) £20 delivered
[Edited on 20/11/13 by yellowcab]
[Edited on 21/11/13 by yellowcab]
JeffJeffers
posted on 19/11/13 at 10:44 PM Reply With Quote
U2U about clutch cylinders.
Badger_McLetcher
posted on 19/11/13 at 11:26 PM Reply With Quote
U2U'd regarding the hoses.
If disfunction is a function, then I must be some kind of genius.
yellowcab
posted on 19/11/13 at 11:40 PM Reply With Quote
Replied to both of you :-)
yellowcab
posted on 20/11/13 at 08:39 AM Reply With Quote
Bosch High pressure fuel pump, fully working order - BOSCH 0 580 464 038 - £60
Low pressure fuel pump, fully working order - £15
samjc
posted on 20/11/13 at 10:21 AM Reply With Quote
Im intrested in the calipers. Only need the rears tho as might try fit them instead of my big volvo 4pots u2u me some measurements for fixing holes and gap between the pads as my discs are 10mm but will double check.
Jon Ison
posted on 20/11/13 at 03:30 PM Reply With Quote
I've got £40 in PayPal how's about the oil/temp gauge ?
yellowcab
posted on 20/11/13 at 03:42 PM Reply With Quote
You always look after me so yup - sold to Jon (u2u sent)
yellowcab
posted on 20/11/13 at 03:44 PM Reply With Quote
Racetech gauge - Sold to Jon Ison
Slave cylinder only - sold to JeffJeffers
Master cylinder still available
yellowcab
posted on 21/11/13 at 07:14 AM Reply With Quote
Braided brake hoses now sold.
yellowcab
posted on 22/11/13 at 05:01 PM Reply With Quote
Sierra front disks, calipers & pads now - SOLD!
JeffJeffers
posted on 24/11/13 at 09:16 PM Reply With Quote
Clutch slave cylinder arrived yesterday morning.
Thanks for the fast delivery.
yellowcab
posted on 24/11/13 at 09:45 PM Reply With Quote
Glad it got there OK - thanks for letting me know
More bits for sale - for a Suzuki Hayabusa engine:
Westfield Megabusa Hayabusa drysump pan, slightly scraped but still solid - £40 delivered
Westfield Megabusa Hayabusa drysump pan, as new condition with pipes as pictured - £55 delivered
yellowcab
posted on 24/11/13 at 09:48 PM Reply With Quote
More stufffffff for sale:
Adjustable fuel pressure regulator, push fit connectors, could do with a clean up - £25 delivered
yellowcab
posted on 24/11/13 at 10:42 PM Reply With Quote
Fuel pressure regulator - SOLD
yellowcab
posted on 25/11/13 at 06:06 PM Reply With Quote
Fuel pressure regulator - dispatched
Front Sierra brake calipers, pads & discs - dispatched
CosKev3
posted on 26/11/13 at 03:52 PM Reply With Quote
Brakes received thanks
Very well packed.
yellowcab
posted on 26/11/13 at 03:55 PM Reply With Quote
Many thanks for the feedback Kev I too got an email saying you'd signed for them at 12:50pm
I was actually annoyed with 'iPostParcel' as they should have collected on Friday, not yesterday, but they never turned up!
CosKev3
posted on 26/11/13 at 03:59 PM Reply With Quote
That is annoying when that happens!Atleast there was no rush for them!
Got here safe and sound is the main thing.
Stripped ready for refurb allready
yellowcab
posted on 28/11/13 at 05:12 PM Reply With Quote
To the top
