Author: Subject: What are these called ??
Brett Jones
posted on 5/12/13 at 10:11 PM Reply With Quote
Could someone please tell me what these are called and are they standard on the Ford Sierra drive shafts, if so where can I purchase them from?
[img][/img]
http://mnrvtecvortxbuild.blogspot.co.uk/
CNHSS1
posted on 5/12/13 at 10:36 PM Reply With Quote
Red arrows
Sorry. I just went into the local ford dealer and showed the parts guy a pic, he brought up on the microfische and bobs your uncle. They are std on sierras, some granadas and escort cosworths
Scuzzle
posted on 5/12/13 at 10:39 PM Reply With Quote
I'd think about lock wiring those socket head bolts in, I've seen them loosen off from horsed up tight loads of times.
robinj66
posted on 5/12/13 at 10:52 PM Reply With Quote
I don't think there's any official name for them - they've been referred to as "drive shaft washers" or "banana washers" or even "two hole washers".
Word is that Ford still stock them.
scimjim
posted on 5/12/13 at 10:56 PM Reply With Quote
That's an SS1 - yours?
You don't need the special "twin hole" washers - you can just use normal ones.
femster87
posted on 5/12/13 at 11:03 PM Reply With Quote
Flanges ?
Same as these? http://drdracing.com/rear-end-parts.html
[Edited on 5/12/13 by femster87]
NigeEss
posted on 5/12/13 at 11:59 PM Reply With Quote
So, your local Ford dealer is open at 36 minutes past ten in the evening !
Awesome :-/
stevebubs
posted on 6/12/13 at 12:35 AM Reply With Quote
Awesome :-/
http://www.etis.ford.com/
http://plus.fordecat.com/
[Edited on 6/12/13 by stevebubs]
mcerd1
posted on 6/12/13 at 08:29 AM Reply With Quote
and any other car with 100mm bolt on lobro CV joints
some of the VW's use the same size ones I think....
[Edited on 6/12/2013 by mcerd1]
Brett Jones
posted on 6/12/13 at 08:44 AM Reply With Quote
Thanks for all the replies and no it's not mine.
CNHSS1
posted on 6/12/13 at 09:18 AM Reply With Quote
OEM the CVs and shafts come with a paper gasket between them, which compress over time and slacken. If you don't use the gasket, just boll*ck up to FT, and then a thin smear of silicone around the joint to stop any CV grease making a bid for freedom
DW100
posted on 6/12/13 at 01:01 PM Reply With Quote
I've never seen one with a paper gasket, but oem usually fit either heavy section spring washers under the bolt or locking compound on the thread.
plantman
posted on 6/12/13 at 07:42 PM Reply With Quote
I just used spring washers
still nice and tight only checked last weekend and I am pushing 300horses
posted on 6/12/13 at 07:55 PM Reply With Quote
I just use threadlock. Sorted.
