Hugh Jarce
posted on 28/10/04 at 04:54 AM |
Correct use of axle stands.
Here's a very safety consious bloke working under his car.
The pay isn't very good , but the work's hard.
Mk-Ninja
posted on 28/10/04 at 06:53 AM |
I hope Chrisg is taking notes.
Looks like its a piece of 4x2 on his christmas list.
I'm sure I've got one, just don't know where I've put it
posted on 28/10/04 at 07:34 AM |
just hope he remembered the hand brake and chocked the wheels!
marktigere1
posted on 28/10/04 at 07:47 AM |
I hope he's not welding too near the fuel tank
Mark
If a bolt is stuck force it.
If it breaks, it needed replacing anyway!!!
(My Dad 1991)
Hugh Jarce
posted on 28/10/04 at 07:54 AM |
It actually looks like he's welding that damp looking area at the bottom of the tank.
Cita
posted on 28/10/04 at 05:55 PM |
What's wrong with that set up?
john_p_b
posted on 28/10/04 at 06:11 PM |
could be worse
he coulda been using breeze blocks to support it
Guinness
posted on 28/10/04 at 07:22 PM |
i bet that the welding kit is connected via a set of jump leads to a lamp post or pylon!! Do you think he's got an RCB on that?
Mark Allanson
posted on 28/10/04 at 08:59 PM |
I was working late one night and an apprentice was welding up his mums car, a Talbot Horizon. It had a moderate sized hole in the boot floor, I
advised him to cut the hole out completely and clean up the edges. I went back into the office to do some invoicing and about an hour later went out
to see how he was doing. He had cut out the hole in the floor to about 8" x 12" and found another hole in the secong skin of the floor,
and had cut out a section about 4" x 4" and welded in a joddled plate. He was just making up the second plate to finish the job.
Horizons do not have a double skinned boot floor, he had just welded up a hole in the top of the fuel tank!
Ignorance is bliss.
madforfishing
posted on 31/10/04 at 08:05 AM |
Why didn't the guy in the picture just lift THE OTHER SIDE ?
posted on 31/10/04 at 08:35 AM |
Think about it....
The props would have got in his way, he's not that stupid .
Cita
posted on 1/11/04 at 07:20 AM |
Nice one Pete!
chrisg
posted on 2/11/04 at 07:41 PM |
Nowt wrong with that!
I've got some crutches he can borrow if he wants.
Seriously, I thought my axle stands and stuff were in place, they wern't.
CHECK EVERYTHING before you get under a car, I was lucky, just a broken pelvis and internal bruising. If I'd have been working under anything
heavier than the Locost I'd have been sending you this message via a medium.
Think on
Chris
Note to all: I really don't know when to leave well alone. I tried to get clever with the mods, then when they gave me a lifeline to see the
error of my ways, I tried to incite more trouble via u2u. So now I'm banned, never to return again. They should have done it years ago!
