Author: Subject: Help-my car has measles-attack of the road salt?
davidimurray
posted on 30/12/13 at 06:02 PM Reply With Quote
My car has aluminium side panels and rear tub. Before my IVA at the start of November I polished all the aluminium with meguiars metal polish which I understand protects the metal.
After all the mucking around with the dvla, I finally got the car on the road on Xmas eve and since then I've done 230 miles.
Putting the car away last night I noticed some spots on the aluminium. Cleaned the car down today and it is covered in spot marks on the ALU - the car looks like it has got measles. The marks don't wipe off and need a hell of a polish to get them to become less visible hopefully they will disappear with more elbow grease.
I am guessing that this is road salt eating the alu? What can I do to protect the ALU after I polish it again? Any tips for polishing the marks out?
[Edited on 30/12/13 by davidimurray]
Gallery 1 http://www.facebook.com/media/set/?set=a.116893465324.130778.601005324
Gallery 2 http://www.facebook.com/media/set/?set=a.245243755324.181913.601005324&l=a9831a9319
Gallery 3 http://www.facebook.com/media/set/?set=a.440671625324.232627.601005324&l=3f0d42c523
Gallery 4 http://www.facebook.com/media/set/?set=a.490098255324.297598.601005324&l=efb083b7df
Gallery 5 http://www.facebook.com/media/set/?set=a.10150244028550325.366987.601005324&l=583fd5cd3a
Gallery 6 http://www.facebook.com/media/set/?set=a.10150550640070325.430417.601005324&type=3&l=fe779b358c
Duratec Engine Swap https://www.facebook.com/media/set/?set=a.10152527759580325.1073741828.601005324&type=1&l=40aae5e72f " target="_blank"> https://www.facebook.com/media/set/?set=a.10152527759580325.1073741828.601005324&type=1&l=40aae5e72f
ste
posted on 30/12/13 at 06:58 PM Reply With Quote
Lacquer it. Bare metal will corrode unless constantly cleaned and polished
Dave Bailey
posted on 30/12/13 at 07:07 PM Reply With Quote
I plan to paint mine....
Dave B
Proby
posted on 30/12/13 at 07:36 PM Reply With Quote
If you want to keep the bare look, either lacquer or maybe a clear paint protective vinyl??
Visit GraphicMonster
black fingernail
Contributor
Posts 144
Registered 2/7/09
Location devon
Member Is Offline
Photo Archive Go!
Building: finished? scratch built book locost with 1700 puma
posted on 30/12/13 at 07:57 PM Reply With Quote
I wipe mine over with wd 40 or duck oil after polishing or washing, it lasts for ages.
steve m
posted on 30/12/13 at 08:00 PM Reply With Quote
As a fellow Alui locoster, I was not aware of any lacquer that could be applied to a polished finish, hence my car does not go on the roads at this time of the year
I would use "Peek" to go over the alui, to get it back to an all alui finish, even " t cut" works, but do it soon, as the salt will EAT the alui in a very short space of time
posted on 30/12/13 at 08:13 PM Reply With Quote
The best polish I have found,way better than Maguires is akalifornia Customs Original Purple Polish, the only problem is finding it
davidimurray
posted on 30/12/13 at 09:01 PM Reply With Quote
Thanks everyone
Unfortunately pant or vinyl are not options at the moment.
I've done a quick experiment on a bad area tonight, t-cut with a hard polishing pad on the drill. Marks seem to be clearing slowly although I think it is going to be a slow job, particularly on the back panel.
Remembered I had a can of acf50 in the garage that I normally use to coat the motorbike in winter. Tried it on a polished area and while it took the shine off the panel still looked clean and if it neutralises the salt and protects it then it will be worth it.
stevebubs
posted on 30/12/13 at 10:11 PM Reply With Quote
Numpty question - Can you wax polished aluminium? If so, I presume this would protect it?
[Edited on 31/12/13 by stevebubs]
coyoteboy
posted on 31/12/13 at 01:48 AM Reply With Quote
Nothing other than a proper adhered or anodised finish will protect a highly reactive metal in the presence of salt. Even the best waxes will only last an outing or two at best.
