Author: Subject: Clecos, is it just me or are they v expensive?
jps
posted on 30/12/13 at 07:59 PM Reply With Quote
I'm hoping to attach my floor soon, Ali sheet to be riveted and bonded on. I * think* it would be a good idea for me to use clecos when drilling the many holes for the River's but given I'm expecting to use upwards of 50 rivets to do the floor it seems expensive, the fasteners look like they are about a quid each?!
Have I missed the point somewhere?
rdodger
posted on 30/12/13 at 08:08 PM Reply With Quote
Maybe you have missed the point.
For 50 holes you don't need 50 clecos. You only need to hold the piece in place. A dozen should be enough.
wilkingj
posted on 30/12/13 at 09:28 PM Reply With Quote
A very useful tool. I have used mine several times since building the Viento.
Not cheap, not used that often. But would not want to be without them.
Agree.. you only need a dozen or so Clecos.
Geoff
Best Regards
Geoff
http://www.v8viento.co.uk
Canada EH!
posted on 30/12/13 at 09:33 PM Reply With Quote
WE are not building aircraft, 10-15 should be all you need to hold the floor in place while you drill the rest of the holes.
When drilling the holes work from the centre out and use clamps in the corners.
Check if there are any aircraft spares shops around, clecos last almost forever, I walked around De Havilland Canada years ago and they just threw them on the floor when removed from the work and swept them up later with a broom.
Duncan36
posted on 30/12/13 at 09:40 PM Reply With Quote
I thought the same recently as I was about to start a build. 2 rivets pushed in place and a bit of masking tap pulling them towards each other has worked quite well holding the panels in place.
www.acorn-printing.co.uk
www.tshirtuk.com
sdh2903
posted on 30/12/13 at 09:52 PM Reply With Quote
They are widely used in the aircraft industry, this means manufacturers can double or if not treble the price. You do get what you pay for though as they are very good.
designer
posted on 30/12/13 at 11:07 PM Reply With Quote
Clecos are worth every penny.
les g
posted on 31/12/13 at 12:24 AM Reply With Quote
Nope clecos are actually cheap as chips if you buy them from the right place !!!!!!
search for a link by ashg ...ash g ...he posted up a link to a uk aircraft supplie/builders and they was cheap as chips !!
sorry but i dont have the link
les g
les g
posted on 31/12/13 at 12:31 AM Reply With Quote
sorry it has just come back to me ...Google ....LAS AEROSPACE LTD pliers are about £3.52 and pins are about 38 p each
cheers les g
atm92484
posted on 31/12/13 at 01:00 AM Reply With Quote
I have about 40 and it seems like a good number. It seems like half of them are always tied up holding something in place temporarily.
Keep shopping around - used aircraft tool places are also a good source.
I don't know if they'll ship to the UK or if shipping will be an arm and a leg but I use these guys for new ones: https://www.aircraftspruce.com/catalog/topages/sheetholder.php?clickkey=3620
-Andrew
Build Log
serieslandy
posted on 31/12/13 at 09:20 AM Reply With Quote
As Les says, mine came from LAS Aerospace.
Pliers here
Pins here
I think I ended up buying about 40 of these and have been really useful all the way along my build
iank
posted on 31/12/13 at 09:27 AM Reply With Quote
Frightening then that they are double/triple the price at kitcar specialists compared to aircraft suppliers...
Anonymous
prawnabie
posted on 31/12/13 at 10:35 AM Reply With Quote
Is there a common size or do us builders use a range of sizes?
serieslandy
posted on 31/12/13 at 10:38 AM Reply With Quote
The 1/8 ones in my link are what I used. 3.2mm in new money.
iank
posted on 31/12/13 at 10:41 AM Reply With Quote
Most kits restrict themselves to 3.2mm and 4.8mm both are really imperial sizes (1/8" and 3/16" ) written in metric.
[Edited on 31/12/13 by iank]
Anonymous
Wheels244
posted on 31/12/13 at 02:15 PM Reply With Quote
Thanks peeps - I've just ordered a set of pliers and 40 clecos.
I've been wanting some of these for ages.
LCBs does it again
big_wasa
posted on 31/12/13 at 02:38 PM Reply With Quote
Many many years ago there was a group buy, I bought 20 3.2 and 20 4mm. very handy.
sdh2903
posted on 31/12/13 at 03:29 PM Reply With Quote
If you need a really tight hold with something these are good too as you can wind them up nice and tight.
http://www.lasaero.com/site/products/article?id=X01A0QWGL
posted on 31/12/13 at 04:10 PM Reply With Quote
That's what I used - I got given a handful by an ex-RAF aircraft fitter (from the WW2 era) - and they do work well. Not as quick as clecos, but I was in no hurry...
jps
posted on 31/12/13 at 09:40 PM Reply With Quote
thanks for the tips on where to source them from.
is a sensible assumption to make that this means I'll be drilling 3mm and 5mm holes to fit most of my panels?
I am assuming that I'll be buying rivets in metric ( my drill bits are all metric, and i can't recall seeing imperial drill bits anywhere recently...)
iank
posted on 1/1/14 at 12:39 PM Reply With Quote
I bought 3.2mm and 4.8mm drill bits when I did mine (got them from screwfix back then, but they only do 0.5 mm steps now).
Toolstation do 3.2mm cobalt bits for not many pennies http://www.toolstation.com/shop/Power+Tool+Accessories/Cobalt+Drill+Bits/d80/sd1230
and 4.8mm in packs of 10 cheap bits suitable for steel. http://www.toolstation.com/shop/HSS+Jobber+Metric+Drill+Bit/p14451
Anonymous
posted on 1/1/14 at 02:20 PM Reply With Quote
Yep - either get a number of 1/8" drill bits, or get a bunch of 3.2mm drill bits from an on-line supplier such as Tracy Tools (who can also sell you 1/8" bits, if you really want them).
atm92484
posted on 1/1/14 at 06:03 PM Reply With Quote
Its nit picking but ideally you should be using a #30 bit (0.129") for a 1/8" hole and #10 (0.194") for a 3/16" hole. The extra clearance allows the rivet to swell to fill the hole and creates a tighter fit.
[Edited on 1/1/14 by atm92484]
-Andrew
Build Log
jps
posted on 19/2/14 at 12:49 PM Reply With Quote
Originally posted by atm92484
Its nit picking but ideally you should be using a #30 bit (0.129" for a 1/8" hole and #10 (0.194" for a 3/16" hole. The extra clearance allows the rivet to swell to fill the hole and creates a tighter fit.
Hadn't spotted this last post - but have just been looking at the complex world of 'which rivet to buy' and have found this advice:
http://www.ebay.co.uk/gds/A-Guide-to-Rivet-Sizes-by-www-abouttownbolts-co-uk-/10000000019327603/g.html
"...for a 5mm hole you'd go for a 4.8mm rivet etc..."
So i'm assuming that my 3.2mm rivet will need to go in a 3.5mm hole.?
Never thought this would be so complicated!!!
