Author: Subject: BEC Propshaft and radiator
b3ngy
posted on 2/1/14 at 08:36 PM Reply With Quote
Starting to have a bit of a clear out of all parts laying around in my garage.
BEC propshaft which is a modified sierra unit believed to be supplied by MK but I can't guarantee that. It has Sierra diff flange and BEC sprocket adapter flange. Just had brand new centre bearing and rubber mount from Graham Goode.
Dimensions are........
Diff flange to centre of centre bearing approx 905mm
Centre of centre bearing to BEC adapter flange 485mm (retracted)
Same as above but extended 525mm
[img] Description
[/img]
[img] Description
[/img]
Looking for £60 Collected but willing to package it up if you want to arrange courier at your expense.
Escort type radiator. Overall dimensions including end caps 395x480mm. Inlet/Outlet 25mm diameter, bleed hose 8mm diameter. The bottom pipe has been repaired with some sort of sealant in the past and has started to weep water, could really do with being repaired properly. Fan is included as well.
[img] Description
[/img]
[img] Description
[/img]
££££ Offers on this as I'm not really sure what its worth given the condition. Looking at £10 postage.
Joelove
posted on 4/1/14 at 11:32 PM Reply With Quote
hi do you have the flange that fits the bike engine side? if so what engine is it for
b3ngy
posted on 5/1/14 at 10:10 AM Reply With Quote
No I don't have the sprocket adapter. You can get them from various companies though.
b3ngy
posted on 7/1/14 at 07:53 PM Reply With Quote
Still available. BTTT.
b3ngy
posted on 19/1/14 at 08:10 PM Reply With Quote
Open to offers......its taking up space!
Joelove
posted on 19/1/14 at 08:59 PM Reply With Quote
£40 for the prop delivered?
b3ngy
posted on 21/1/14 at 09:04 AM Reply With Quote
Prop shaft sold.
