Author: Subject: Roof Felting
OliilO
posted on 3/1/14 at 02:22 PM Reply With Quote
Roof Felting
I'm in the process of reroofing a small shed and have reached a bit of a dilemma.
I've replaced the wood, however it then starting raining hard the other day and I left it unfelted to do when it was dry. Now the forecast looks poor, I'd like to finish it but laying felt on damp wood doesn't seem like a good plan as I'd imagine the moisture will get trapped.
So is it best to leave it unfelted and wait until the wood has dried fully (who knows when that'll be!) or felt it with some moisture in the wood to stop the shed getting damper now? It's 18mm OSB if that makes any difference.
Oli
JohnH
posted on 3/1/14 at 02:31 PM Reply With Quote
Was the OSB conditioned ? If so you should be able to felt it.
r1_pete
posted on 3/1/14 at 02:54 PM Reply With Quote
I'd do a temporary job, with the felt, if you've enough or some cheapo visqueen (sp) spaced at 20 or 30mm from the wet roof, that way you will prevent further water ingress and allow the timber to breath and dry. Then do the job properly in better weather / when its dry.
van cleef
posted on 3/1/14 at 03:10 PM Reply With Quote
Just felt it and it'll be fine....
I'm a roofer by trade and we sark tiled roofs up here (NE Scotland )with it above the trusses. Sometimes the OSB sits nailed on the roof for days before it's felted and the worse case scenario is that it'll swell a little, but it won't ruin the integrity of the board.
gottabedone
posted on 3/1/14 at 06:28 PM Reply With Quote
Let it dry out naturally (no added heat and it should be fine)
jossey
posted on 3/1/14 at 08:24 PM Reply With Quote
tarpoline it for now and come back to it when the weather dries up.
tuck the tarp under the wood and nail in with tarp nails and put card on the corners to stop it splitting the tarp.
the felt maybe ok if the wood dries out but may rot.
David Johnson
Hopley89
posted on 3/1/14 at 08:54 PM Reply With Quote
Hi I'm the same as van cleef I'm a roofer by trade and have been for years
I'm a built up felt roofer
AND IT WILL BE FINE TO FELT
