alland3851
posted on 6/1/14 at 01:13 PM |
Oversized Pinto Pistons
Hi, I am looking for a set of +0.75mm(0.030" HC Pistons for a 2.0l SOHC Pinto. Anybody got a set or any help as to where I might be able to
source them would be appreciated.
Not Anumber
posted on 6/1/14 at 02:31 PM |
Is this something you are planning or have the cylinders already been bored out to +0.75 ?
I looked into it when rebuilding my Pinto and ended up going for +0.50 as the pistons were more readilly available. You would not notice tany
difference in power between the two.
mcerd1
posted on 6/1/14 at 03:21 PM |
burton power normally sell cast AE ones in +0.75mm (9.2:1 CR)
although it says low stock at the moment
(if you phone them they'll tell you when they are expecting more)
but they also do some in +0.5mm, +1.0mm and +1.5mm (and the 2.8 V6 ones that give +2.25mm)
http://www.burtonpower.com/parts-by-fitment-type/parts-by-engine-ford/ford-sohc-pinto.html?limit=40&product_area=745&product_group=293
[Edited on 6/1/2014 by mcerd1]
garyo
posted on 6/1/14 at 03:42 PM |
It's there a cheat on this - something like using Fiesta Diesel pistons? Or are they the ones that give you a higher CR on a standard bore
size?
Gary
alland3851
posted on 6/1/14 at 04:09 PM |
Hi, the engine has been bored to +0.75. This is originally a Transit engine that was reconditioned hence the odd size. Unfortunately they put in the
LC Pistons.
I don't know if any other pistons would fit.
garyo
posted on 6/1/14 at 05:37 PM |
I'll have a look for you tonight - I've got a feeling there was some combo of Fiesta pistons and 2.8 V6 rods, or vice versa, that might
work (you might need to machine a little off the top of the pistons to avoid too high a CR, but it could be cheaper than a new set of pistons)
It's in Des Hamill's Pinto/YB book.
Gary
alland3851
posted on 6/1/14 at 07:05 PM |
Thanks for that Gary, much appreciated
Allan
posted on 6/1/14 at 08:15 PM |
2.8 V6 Pistons might be suitable IIRC as well as modified 1.8 diesel con rods for extra strength( cheaper than Cossie rods)
garyo
posted on 6/1/14 at 09:11 PM |
This isn't as much help as I thought, but here it is for the sake of completeness on the thread:
The 2.8 V6 Granada pistons will take 8500 rpm and are 93mm diameter taking the capacity to 2094cc. So you'd need a re-bore to fit them to your
transit engine. If used with standard con rods you'll be well down on compression. However, used in conjunction with Fiesta 1600 diesel rods,
the pistons will be flush with the deck. The fiesta rods will also take 8500 rpm if you lighten the little end. Unfortunately the Fiesta rods
aren't a drop-in fit - they need the big-end re-boring, and the fully floating small end means you need to fit teflon buttons to keep it in
place.
So - perhaps you could use the pistons if a re-bore works out cheaper than a new set of oversized pistons, but both options might be pricey compared
to getting a standard 2.0 pinto as a replacement. The book doesn't say how much you can machine off the top of a block, but says 0.75mm would
take the CR from 9.2 to 9.9.
Gary
mcerd1
posted on 6/1/14 at 10:01 PM |
the V6 pistons are the ones burtons sell as +2.25mm
you'll also need a '205' block to be 100% sure its safe to bore it that big...
I've heard of the 1600 diesel rods being used as is, but offset grinding the crank to the smaller size to increase the stroke
not sure what pistons they ended up with to make all that work but I'm sure it cost several hundred £ to do all the re-machining alone - its
just not worth it !
a re-bore up to +1.0mm is the best option if +0.75mm pistons aren't available (but check with burtons first, they might have +0.75mm ones due in
stock soon for all you know )
alland3851
posted on 7/1/14 at 02:39 PM |
Thanks for all the info and suggestions. I think the easiest,most cost effective , will be to contact Burtons for a stock outlook on the +0.75
pistons.
Thanks to all.
Allan
