Author: Subject: RCA Cable
Scuzzle
posted on 24/1/14 at 12:56 PM Reply With Quote
RCA Cable
Fitting some audio to my daily driver and the RCA cable I am using to an amplifier has a single core wire running up the middle of the 2 RCA leads which I'm not sure what to do with. Is it some kind of ground or do I just ignore it, it's very thin, almost non existent but I don't get why it's there or what it's for.
dinosaurjuice
posted on 24/1/14 at 01:43 PM Reply With Quote
A lot of cables have a strand of something (not sure what it is) to stop them stretching and damaging the copper.
Just cut it flush when you strip ends
alistairolsen
posted on 24/1/14 at 01:45 PM Reply With Quote
its supposed to be used for the 12v trigger from the headunit to the amp, but its a bad idea mixing power and signal lines so I always run a separate 12v down the opposite sill.
My Build Thread
loggyboy
posted on 24/1/14 at 02:26 PM Reply With Quote
Aii, its intended as a remote signal.
Mistral Motorsport
theduck
posted on 24/1/14 at 03:22 PM Reply With Quote
Yep remote signal. Shouldn't affect sound tbh.
bi22le
posted on 24/1/14 at 04:53 PM Reply With Quote
Yep. It won't affect signal quality. If it did you would hear all sorts going on.
Please read my ring story:
Scuzzle
posted on 24/1/14 at 04:57 PM Reply With Quote
Thanks for the replies, I'll just leave it alone then, it's so thin it looks good for nothing anyway. The remote is always on the other side of the amplifier in between the live and the earth, never on the same side as the RCA inputs so looks a bit of waste of time.
