Author: Subject: cleaning paint off threads
peter030371
posted on 25/2/14 at 08:01 PM Reply With Quote
So my car is slowly coming together but I am a little stuck on my Striker the lower front wishbones have a large threaded hole for a metro ball joint. This thread has very helpfully been powder coated...how do I clean the thread?
Not got it in front of me but its circa 35mm thread so I don't have a tap in my set that big
Does a magic tool I have never seen exist?
theprisioner
posted on 25/2/14 at 08:19 PM Reply With Quote
If it is a male thread use a Thread file typical example: ebay:181332259968
http://sylvabuild.blogspot.com/
http://austin7special.blogspot.co.uk/
gremlin1234
posted on 25/2/14 at 08:20 PM Reply With Quote
make one
for cleaning a thread, any old bolt/fitting with a saw cut or angle grind, should work.
similarly, a nut with cut through it will clean an external thread.
now ask why did I throw out that decrepit old metro ball joint...
gremlin1234
make one
posted on 25/2/14 at 08:44 PM Reply With Quote
If you have an old ball joint just file a flat or two on the threads before screwing it into the threads to clean them . Failing that use a small rotary wire brush in a die grinder or Dremel type tool,finish off using a new ball joint
posted on 25/2/14 at 10:16 PM Reply With Quote
Assuming you need to clean a female thread (you mentioned not having a tap), then I would run a scalpel vertically around the thread to take the powder coat of to tops of the thread. Once you've broken through, then use a sharp scribe to run carefully around the bottoms of the thread. The powder coat should come out relatively easily.
Madinventions
posted on 25/2/14 at 11:21 PM Reply With Quote
I used a blob of Nitromors on a cotton bud for mine. I just waited for it to do it's thing then cleaned it out with a combination of cloths and brushes. Probably the least chance of any damage to the threads doing it like this?
View my band website:
http://www.shadowlight.org.uk
loggyboy
posted on 26/2/14 at 01:27 AM Reply With Quote
Use a sharp knife to cut around the rim of the thread, then scrape a small amount away from the first thread or 2, enough to get a bolt to bite. Spray with wd40 and tighten and loosen bolt till it removes any powder coat. The cut edge will reduce chance of powdercoat cracking away from the thread hole.
If coating is really thick and deep in the hole, and you have a spare bolt you could try hack sawing a small cut against the thread direction to get it to bite into the coating. Turn it back and forth as if using a tap.
Mistral Motorsport
ashg
posted on 26/2/14 at 06:01 AM Reply With Quote
one of these on the end of a drill or buy the correct tap if you want to do a really good job
http://www.toolstation.com/shop/Power%20Tool%20Accessories/Wire%20Abrasives/Decarb%20Wire%20Brush%20Set/d80/sd1920/p53351
Haynes Roadster (Finished)
Exocet (Finished & Sold)
New Project (Started)
peter030371
posted on 26/2/14 at 09:26 AM Reply With Quote
Thanks for all the suggestions, lots of good ideas for me to work through
40inches
posted on 26/2/14 at 09:53 AM Reply With Quote
This is what I would do, a 35mm dia hole gives plenty of working space. Wonder how much a tap would cost
