New Topic New Reply
Author: Subject: Measurment required
Thailoz
posted on 26/2/14 at 11:24 PM Reply With Quote
Measurment required
Can anyone tell me what is the distance rom TR9 to the center of the gear stick so it dosent hit the the dash etc. I am using a toyota T50 gear box
[Edited on 26/2/14 by Thailoz]
It may sound a dumb Question to you but to others it may be an eureka moment
Canada EH!
posted on 27/2/14 at 01:39 AM Reply With Quote
You need to shorten the gear lever or it will hit the dash. The T50 gearlever is closer to the firewall than that of the Ford transmission. The 4AGE engine can not be moved further to the rear to solve the problem especially if using the FWD version.
Thailoz
posted on 27/2/14 at 12:01 PM Reply With Quote
thanks for reply tho I am not using a 4ge I am using a 4k engine
Canada EH!
posted on 27/2/14 at 02:44 PM Reply With Quote
Don't know that engine, just move the engine as far back as the engine or transmission will allow leaving at least 70 mm from the firewall and transmission tunnel to allow for engine movement.
Canada EH!
posted on 27/2/14 at 02:48 PM Reply With Quote
The original Lotus gearshift levers were only about 100 mm long.
New Topic New Reply
