Author: Subject: 1600 crossflow block
arrow-engineering
posted on 10/3/14 at 10:38 PM Reply With Quote
im after a crossflow block and main caps please
711 block if possible, ax if im lucky
dont mind if its already bored up to 0.060" as i will be going +0.090.
im in chesterfield, derbyshire/south yorkshire area
07891 604755
thanks
jollygreengiant
posted on 11/3/14 at 07:53 PM Reply With Quote
NTDWM. But I just spotted this on the bay. Ford Kent OHV Crossflow / Xflow 1600cc 7IIM Full Engine MK2 Cortina. MK1 Escort
Monty2556
posted on 13/3/14 at 05:23 PM Reply With Quote
I've looked at that motor and asked the question is it a 711 block. I've asked the question three times and had no reply. I presume it's not a 711 block.
arrow-engineering
posted on 13/3/14 at 11:22 PM Reply With Quote
i think you arent getting a reply because the seller might think you are taking the micky, if you look at the pictures you can see the block number very clearly 711M6015BA.
Monty2556
posted on 14/3/14 at 10:10 PM Reply With Quote
Ah yes I see what you mean but I got my wires crossed and was referring to a different 1600 xflow. I'd been looking at both of them and after a while they merged into one!! The one I couldn't get a reply from was ebay no.291095999764 and I did eventually get a reply which said that the number on the block was 691m60158a. Am I right in saying that the "A" at the end of the number denotes a 1300 not a 1600. Good job I didn't buy it!!
arrow-engineering
posted on 15/3/14 at 11:11 AM Reply With Quote
711m6015ba is 1600 block
711m6015aa is 1300 block
this also applies to the block numbers starting 681/691 etc etc
the reply you got stating 691m60158a has been misread, the 8 is meant to be a b, so that block is an earlier casting, from 1969, in 1600 size. this engine has the stronger main caps like the 711 block but smaller bore followers like the preceding 681 blocks
Marcus
posted on 15/3/14 at 02:47 PM Reply With Quote
U2U sent
Marcus
Because kits are for girls!!
Monty2556
posted on 16/3/14 at 06:50 PM Reply With Quote
As I can't find a 711 block is it worth buying a 691 block if I don't intend any radical tuning. Considering a GT head, mild road cam, 4 branch exhaust and a twin choke Weber. I'm not intending reving the nuts off the engine.
