Author: Subject: ZZR 1100 Coil Pack Help!
zzr-fleet
posted on 15/3/14 at 09:27 PM Reply With Quote
Hi
I just bought a Locost with a zzr 1100 D engine (bought as a project)
Could anyone please tell me what coil packs should be on this engine? i was told its got the wrong ones on it (from a previous engine)
jossey
posted on 15/3/14 at 11:59 PM Reply With Quote
Not sure I understand the question but any of the zzr1100 range should work ok. Also the zzr1200 ones worked fine on mine.
David Johnson
zzr-fleet
posted on 16/3/14 at 12:05 AM Reply With Quote
Ok thanks. I think the ones that are on it now might be off the fireblade engine previously fitted and im having problems getting it to run right at the moment.
James
franky
posted on 16/3/14 at 06:46 AM Reply With Quote
I've a set of zrx coils, its a zzr engine in a naked bike
zzr-fleet
posted on 16/3/14 at 11:10 AM Reply With Quote
How much do you want for them? And would you be able to post them?
franky
posted on 16/3/14 at 12:55 PM Reply With Quote
Yes thats fine. £50 posted?
Cadburys Man
posted on 16/3/14 at 10:33 PM Reply With Quote
Did u buy this from Chesterfield by any chance?
Stuart Taylor ZX9-R Locosaki
zzr-fleet
posted on 16/3/14 at 10:35 PM Reply With Quote
Yes I did
zzr-fleet
posted on 16/3/14 at 10:50 PM Reply With Quote
why do you ask? any knowledge would be much appreciated
Cadburys Man
posted on 16/3/14 at 10:56 PM Reply With Quote
It was Skip's car who is a mate of a mate i went to look at it myself for a mate
How much did u pay for it if u don't mind me asking?
Am i right in thinking it only revs properly to about 3000rpm?
Apparently it was originally fitted with a Fireblade engine and when it got changed to the ZZR1100 engine they somehow grafted the Fireblade coil packs into the wiring but it failed to work correctly :-/
zzr-fleet
posted on 16/3/14 at 11:04 PM Reply With Quote
To be honest im struggling to get it to run at all at the moment. It starts and miss fires then cuts out.
I gave 3900 for it
Im going to strip it down and hopefully have it on the road as soon as possible.
zzr-fleet
posted on 17/3/14 at 12:23 PM Reply With Quote
Air box
Could anybody tell me from experience if i would be better off with an air box or foam filter/s on the zzr 1100 engine?
teegray19
posted on 8/4/14 at 05:42 PM Reply With Quote
i think your always best off with the standard air box, due to the RandD Kawasaki will have put into it!
however, i don't have the space for one - and i like open intake noise, so its got a panel filter on.
zzr-fleet
posted on 8/4/14 at 06:45 PM Reply With Quote
What size jets are you using with that filter?
teegray19
posted on 9/4/14 at 07:15 AM Reply With Quote
We'll....
I had two sets of carbs. One had 140 main jets and wouldn't rev past 3k rpm.
The other has 155 mains and seems perfect.
The filter shouldn't change things too much.
What jets are you running?
MK9R
posted on 9/4/14 at 07:33 AM Reply With Quote
I've got a complete zzr bike for sale if you interested INA donor package??? The bike is still all intact so can be ran first to prove its ok
Cheers Austen
RGB car number 9
www.austengreenway.co.uk
www.trackace.co.uk
zzr-fleet
posted on 9/4/14 at 07:02 PM Reply With Quote
Iv got an engine now and most of the bits thanks.
My carbs seem to have 160 jets in outer carbs and 156 on the inner 2. Is there a valid reason for that?
