Author: Subject: ST170 Engine Number Location?
BigDawgV8
posted on 16/3/14 at 08:49 AM Reply With Quote
Hi Guys,
Can anyone tell me where to find the engine number on a Focus ST170 engine please (about 2002 vintage)?
big_wasa
posted on 16/3/14 at 08:53 AM Reply With Quote
Its the same as a zetec.
Just above the crank sensor, on the flat casting where you bolt the bell housing to.
[Edited on 16/3/14 by big_wasa]
Paul Turner
posted on 16/3/14 at 08:54 AM Reply With Quote
If its like all other Zetecs (and it should be since it is one) it is stamped onto a lug on the exhaust side of the engine at the flywheel end at the side of the crank sensor. It usually gets rusted etc since its in the full blast of dirt, salt etc but a wire brush soon reveals the numbers.
BigDawgV8
posted on 17/3/14 at 09:12 PM Reply With Quote
Thanks for the replies.
Sorted!
bombero
posted on 5/12/14 at 11:06 PM Reply With Quote
A small resurrection of this thread - just to ask if a reg no can be obtained if I've got the engine code? This'll help if trying to buy standard engine parts from the dealers in the future..
big_wasa
posted on 6/12/14 at 10:23 AM Reply With Quote
No way that I know of.
Just find a car for sale (ebay) with the same engine and give them that reg.
kingster996
posted on 6/12/14 at 10:43 AM Reply With Quote
I recognise that block. Won't be yellow for much longer though
I used to be indecisive, but now I'm not so sure
big_wasa
posted on 6/12/14 at 12:55 PM Reply With Quote
You have no chance of getting that yellow off
Stuck like sh#t to a blanket. Its a heat proof 2k epoxy mastic that was applied on to a degreased and bead blasted block.
Ask Dave, when I stick something it stays stuck
kingster996
posted on 6/12/14 at 01:36 PM Reply With Quote
Bugger. Oh well might have to consider the look of a yellow block in a red car!
Got a black cam cover already though
Anyway, ultimately it will get swapped for the st170 so might live with it for a season.
posted on 6/12/14 at 07:43 PM Reply With Quote
With hindsight, a normal 2l zetec with some cams and a little head fettling and bike carbs should be close to 200 bhp..
The reason I post this and no idea why the block made me think of nice shiny forged pistons and a turbo.... = an easy 350 bhp...
bombero
posted on 6/12/14 at 09:49 PM Reply With Quote
Can a year of manufacture be gotten from the code? I've got the engine already but I'm just wanting to get a bit more background if possible.
kingster996
posted on 6/12/14 at 09:55 PM Reply With Quote
Yes ford engines have a code that indicates the year. Can't recall where you find it bit Google will know.
bombero
posted on 6/12/14 at 10:00 PM Reply With Quote
I recognise that username .. .. cheers, Chris!
big_wasa
posted on 6/12/14 at 10:06 PM Reply With Quote
First two letters of the engine number show year and month of manufacture. You can look this up on Burton power website.
bombero
posted on 6/12/14 at 10:20 PM Reply With Quote
That's great, thanks! My code is ALDA 2U***** I'll go check out Burton!
big_wasa
posted on 7/12/14 at 09:07 AM Reply With Quote
June 2002
Alda is the engine code
bombero
posted on 7/12/14 at 10:20 AM Reply With Quote
That's great - thanks very much!
