Author: Subject: Fiat seicento steering rack
paddywil
Contributor
Posts 53
Registered 1/4/13
Location Essex
Member Is Offline
Photo Archive Go!
Building: Scratch build midi, Restoring Morris minor travell
posted on 24/3/14 at 10:30 AM Reply With Quote
Hi everyone
I'm looking to use a seicento rack on a single seat midi I plan on building in the near future. Would anyone happen to know the distance between the centres of the mounting holes?
If anyone could tell me I'd be very grateful
Paddy
wicket
posted on 24/3/14 at 12:33 PM Reply With Quote
You could try here
http://www.clubcento.co.uk/
Found them useful when we had a Seicento.
You may have to register to ask questions on the forum
[Edited on 24/3/14 by wicket]
trextr7monkey
posted on 24/3/14 at 02:51 PM Reply With Quote
If answer doesn't turn up quickly we have the factory work s manual at home somewhere and I could look up spec
atb
Mike
paddywil
Contributor
Posts 53
Registered 1/4/13
Location Essex
Member Is Offline
Photo Archive Go!
posted on 24/3/14 at 04:44 PM Reply With Quote
Cheers for that, I'll take a look
If I don't have much luck, I might take you up on that offer mike
Paddy
matty h
posted on 24/3/14 at 05:14 PM Reply With Quote
I am using a fiat cinquecento on my gravity racer if it is the same the centres of the two 12mm mountings is 240mm.
Matty
Benzine
posted on 24/3/14 at 05:42 PM Reply With Quote
just checked the rack in my garage, pretty sure it's from a 600 but it's been a long time. 24cm as said above
EDIT: just found out it's from a Cinquecento
[Edited on 24-3-2014 by Benzine]
paddywil
Contributor
Posts 53
Registered 1/4/13
Location Essex
Member Is Offline
Photo Archive Go!
posted on 24/3/14 at 08:59 PM Reply With Quote
Thanks everyone!!!
That's a really great help, means I can finish up designing the front end of the chassis
Thanks again
Paddy
