Author: Subject: brushing on spray paint
Miks15
posted on 31/3/14 at 12:29 PM Reply With Quote
hey guys,
im rebuilding an old honda bike engine. I'm leaving the side case bare aluminium and have a paint crankcase, block and head. Now i want to put the black detailing on the honda writing on both sides of the engine. so I was going to get a little brush and fill them in by hand.
would there be any problem with spraying paint from a spray can in to a small tub so a small pool of paint builds up and using this with a brush? I don't want to have to buy a pot of paint just for the small detailing.
mookaloid
posted on 31/3/14 at 12:46 PM Reply With Quote
Done that myself lots of times
Slimy38
posted on 31/3/14 at 12:49 PM Reply With Quote
The only problem I found was that there is a whole lot more thinners in the spray can, so I had to spray a lot more than I thought I would, and had to go over the paint a few times to get a solid colour.
Miks15
posted on 31/3/14 at 12:53 PM Reply With Quote
Thanks guys,
Yeah that was the sort of thing i was worried about slimy, wasnt sure how different the make up of the paint was. I might give it a go on a spare cover I have to see how it turns out first.
jossey
posted on 31/3/14 at 01:13 PM Reply With Quote
Spray into a big jug I bought come plastic ones from 1 shop this will enable you let the thinners disperse quicker.
David Johnson
View User's Profile E-Mail User Visit User's Homepage View All Posts By User U2U Member This User Has MSN Messenger
Slimy38
posted on 31/3/14 at 01:16 PM Reply With Quote
This makes sense, I actually tried to stir the thinners back in which was probably the worst thing to do. It was also Halfords spray paint, so a better rattle can might actually have a bit more paint in it.
Miks15
posted on 31/3/14 at 01:29 PM Reply With Quote
so when you say disperse, is is all of the aerosol type bit of the spray that has the thinners in it? so if its sprayed on to a large surface area and then angled to be allowed to form in a corner, this should work better than if just sprayed in to a small tub?
owelly
posted on 31/3/14 at 02:13 PM Reply With Quote
I've sprayed aerosols into the cap and used a tiny brush to touch in scratches. Just leave it a few minutes for the thinners to evsporate.
http://www.ppcmag.co.uk
Davey D
posted on 31/3/14 at 02:36 PM Reply With Quote
At halfords they sell touch up pens for different colours. it has a metal nib one end, so you can use it a bit like a short fat pen, or unscrew the lid, and there is a very fine brush inside
View User's Profile View All Posts By User U2U Member This User Has MSN Messenger
Miks15
posted on 31/3/14 at 07:34 PM Reply With Quote
cheers for the advice guys!
And thanks for the tip Davey, will have a look at them next time im in halfords
posted on 1/4/14 at 09:11 AM Reply With Quote
Originally posted by owelly
I've sprayed aerosols into the cap and used a tiny brush to touch in scratches. Just leave it a few minutes for the thinners to evaporate.
That's the way I do it, there's a fine line between the thinners going and the paint setting. Touch up pens are expensive for what they are it would be cheaper to buy a Humbrol black and use an artist brush.
