<<  1    2  >>
Author: Subject: BT Infinity?
posted on 2/4/14 at 09:14 PM Reply With Quote
BT Infinity?
Thinking of moving from Sky for my broadband to BT for the fibre optic Infinity thing..
Anybody done this? Just wondering how it goes.. price is about the same and the attraction is BT Sport and ESPN included. Plus obviously infinity is much faster than standard broadband.
kingster996
posted on 2/4/14 at 09:28 PM Reply With Quote
I am with bt infinity and it is very fast. Get 70mb down and 20mb up. Been pretty reliable too.
McLannahan
posted on 2/4/14 at 09:46 PM Reply With Quote
I made that move too. It's quite good, not cable good...I would have done that out of preference if it was available. I have the BT Youview box too. There's plenty enough channels and the interface is good. It's a little slower to react than Sky and I do need to reboot the box once a week but it's cheap, and I'm happy in general with it!
I don't really miss Sky and as said, BB speed is good and it's reliable too.
kingster996
posted on 2/4/14 at 10:11 PM Reply With Quote
Mine is easily as fast as cable, was on vm before house move to non cable area. Uploads are twice as fast which is good for me being a web developer.
craig1410
posted on 2/4/14 at 11:56 PM Reply With Quote
I'm using the same fibre to the cabinet technology but with a different ISP, Zen Interenet. Zen are widely regarded as the best UK ISP and I can certainly recommend them. My Dad and a good friend use BT having previously been with Zen and have had problems with speed and reliability. As with most things, you get what you pay for.
Zen isn't cheap but there are better options than BT (eg. Plusnet). Have a look at the ratings on thinkbroadband.com
snakebelly
posted on 3/4/14 at 06:49 AM Reply With Quote
Another vote for Zen, I use them for business, we have them supplying broadband to a couple of blocks of flats we manage the it for and never had a technical issue in over 5 years, also use them for hosting, as said not the cheapest but you get what you pay for.
posted on 3/4/14 at 07:29 AM Reply With Quote
Originally posted by craig1410
... there are better options than BT (eg. Plusnet).
Strangely, Plusnet manage to out-perform BT in many ways - even though they are owned by BT, and use the same infrastructure!
Slimy38
posted on 3/4/14 at 07:37 AM Reply With Quote
I stayed with Sky but moved to Sky Fibre, which is basically rebranded BT infinity. Performance wise it has been spot on, but the main reason for staying with Sky was the 'unlimited' side of things. BT infinity is/was capped remarkably low, I don't know what it is now but it's definitely worth checking first. Had I been with BT I would have hit the cap every single month (IT consultant working from home)
kingster996
posted on 3/4/14 at 08:02 AM Reply With Quote
I am on the top BT Infinity package 70mb ish and no limits. Originally was on their limited package but went over in under a week (IT/Web dev usage!).
Personally, no real problem with BT - only issue I have had in over 1yr was due to the physical cable attached to my property causing intermittent connection. They fixed it within 24hrs.
Daddylonglegs
posted on 3/4/14 at 08:15 AM Reply With Quote
We moved to BT Infinity about 4 weeks ago. Getting between 12 and 35Meg DL and around 5-8M upload so not as fast as some, but much better than with wired BB.
We have also had issues with the box needing resetting a couple of times a week, it seems that when we go to On Demand, if the Internet drops, then the box needs resetting before it will work properly. I intend to give BT a call and see what they have to say. But on the whole it's not too bad.
wilkingj
posted on 3/4/14 at 08:34 AM Reply With Quote
I am biased..... I worked for BT for 41 years, and was part of the BT Internet launch (and pre launch trial) in 1994.
So I have had BT Internet from before day one!
Its always been reliable, and rarely goes wrong.
I have just upgraded to the FTTC (Fibre To The Cabinet) and have copper for the last 1/2 mile or so. Whilst not on the top package, I get a steady and contsant 43.8 Mb download and a good 7.8Mb upload.
I have yet to see anyone who gets the FULL advertised up/download from ANY ISP. I am happy with what I get for what I pay.
My mate in the same village, has full FTTP (Fibre To The Premises) and gets about 75Mb Down and 18.5 Up. He pays a lot more than me, and has static IP addresses with ZEN. He also rates Zen and has been with them for a good while. He is also Technical Manager for a Computer company.
I have known him for over 35 years, and respect his knowlege and judgements when it comes to computer /Internet things.
So thats another +1 for ZEN.
For me, reliability, and service is worth more than a little extra speed.
EDIT.... If you have a BT Hub, leave it on ALL the time. Its does things in background like optimising the speed, and diagnostics. Not a lot, but I never turn mine off.
Sometimes, I have to restart my box (not a full reset to day one data) and this will often clear any speed issues I have had, but not always as it depends where the problem is.
[Edited on 3/4/2014 by wilkingj]
Best Regards
Geoff
http://www.v8viento.co.uk
daveb666
posted on 3/4/14 at 08:49 AM Reply With Quote
I wish I had the opportunity to get BT Infinity.
My exchange has nearly 7,000 residential homes on it and isn't even 'planned' to have Infinity rolled out to it.
The exchange on the other side of the village has just over 7,000 residential homes on it and has had infinity for nearly 6 months.
It really pisses me off that BT are already shouting about Infinity 2' - they should be forced to make sure all exchanges are upgraded to Infinity 1 first.
kingster996
posted on 3/4/14 at 09:57 AM Reply With Quote
I just did a "speed test" and got 38 down, 18 up - and pretty happy with that tbh as I notice the upload speed when transferring large video files up to client's web sites etc. I have had over 70 download in the past (but don't check that often!)
When the engineer was here fixing my external cable issue, he did a test to exchange/cabinet (whatever) and reported that it was "as fast as you can possibly get round here - 80 down and 20 up" - so I guess it is 'capable' of what they advertise, but the interweb itself can be a limiting factor I reckon.
wilkingj
posted on 3/4/14 at 10:17 AM Reply With Quote
You are absolutely right, the Internet is only as fast as the slowest link (connection) in the chain.
Bearing in mind you could be passing through half a dozen different carriers / ISP / networks to get to the destination.
If the speedtest site you are using is NOT in the same ISP's "cloud" as you then you are subject to the slowest link rule.
The Internet, is made up of leterally hundreds of thousands of ISP's and carrier companies. Its not "one" network controlled by any one company.
I am sure that "Grannies" and "eggs" is completely correct here!
Geoff
Best Regards
Geoff
jeffw
posted on 3/4/14 at 11:52 AM Reply With Quote
I have two FTTC connections, one with Plusnet and one with BT. Both of them are 75Mb/s down and 18.5Mb/s up....
posted on 3/4/14 at 04:32 PM Reply With Quote
I live in No 26 and No 31 is at the end, just round the corner is a green box with a 'Fibre optic inside' sticker on it so thats about 150/200 metres away.
Do they run it through the existing twin copper cable or run a FO line into your house?
I had a slow/connection problem with my Sky broadband at the start which was fixed in double quick time by the BT engineer. Turns out he lives in the next street and asked me if I seen anyone in the green box at the end of the street! He rang me up after to say he'd found a loose wire in the box and its been rock solid ever since! What a guy.
Package I'm looking at is the 38mb with a 40gb usage, price is similar to sky but is optic and includes BT sport and ESPN!
Did a speed test last night on my current broadband and got 8.9mb down and /0.87mb up so should be MUCH faster I reckon.
posted on 3/4/14 at 06:02 PM Reply With Quote
I'll let you know how I get on - I have a BT man due to turn up and install FTTC tomorrow morning! Currently getting about 5 - 6 Mbs, so it will be interesting to see what I end up with.
(BTW: I'm on PlusNet)
jeffw
posted on 3/4/14 at 07:30 PM Reply With Quote
Fibre to Cab and then copper the last mile. BT are trialing 300Mb on FTTC. There is also FTTP for business use in certain areas.
posted on 3/4/14 at 09:07 PM Reply With Quote
The local cabinet is less than 1/4 mile away, so it should be interesting...
posted on 3/4/14 at 09:12 PM Reply With Quote
Well, I've done it, paid the money so its coming.. 17/04/2014 to be exact
posted on 4/4/14 at 12:28 PM Reply With Quote
Well, here's the result of the upgrade:
Not at all bad, considering I had just over 5Mb/s before.
In addition, the Openreach bod moved my master socket from an incredibly inconvenient place in the porch to a position just under my desk, which was a huge bonus.
(It actually made life a lot easier for him, too)
jeffw
posted on 4/4/14 at 01:13 PM Reply With Quote
Nice nice....it takes a few days to settle down.
chris mason
posted on 4/4/14 at 03:23 PM Reply With Quote
Think we need some fibre round this way
Local exchange has it and apparently they're taking orders now for fibre, so hopefully the green box will be ready soon
Slimy38
posted on 4/4/14 at 03:39 PM Reply With Quote
I think it's great when you go from being slower than a certain percentage, to being faster than a certain percentage...I went from slower than 83% of GB to faster than 71%.
David, how on earth did you get a 0ms ping? If ever I play call of duty I'm never playing against you!!
jeffw
posted on 4/4/14 at 03:48 PM Reply With Quote
The 0ms ping is a fault with the speedtest and not a real figure. 8ms seems about right for FTTC
<<  1    2  >>
