Author: Subject: Side repeater position
neilp1
posted on 4/4/14 at 07:38 PM Reply With Quote
One of my next jobs is the side repeaters. I was planning on fitting them to the outside edge of the front cycle wings.
I have read the IVA manual, but it doesn't really state where they have to be. I have done a search on here, but couldn't find anything to say not to put them on the front wings.
Neil
posted on 4/4/14 at 07:41 PM Reply With Quote
Does it not say what the viewing angles need to be in the manual?
Then you can work out the best position, or , have look at the recent pass photos on here, or even the fails if that wasnt an issue?
rash12
posted on 4/4/14 at 07:44 PM Reply With Quote
back arches seems to be the favourite at the mo when I asked
neilp1
posted on 4/4/14 at 07:46 PM Reply With Quote
Don't want to mount on rear arches if possible.
theduck
posted on 4/4/14 at 07:56 PM Reply With Quote
Front cycle wings is fine. Indicators are tested with wheels straight ahead and visibility is 5-60degrees rearward. Is all voveref in IVA manual will check section an post back.
neilp1
posted on 4/4/14 at 07:59 PM Reply With Quote
Steve,
here is what the manual says-
Angles of visibility
a. Horizontal
i. 80deg outwards 45deg inwards.
ii. < 750mm above the ground 20deg inwards
iii. (SIDE REPEATER) To the rear between 5deg and 60deg outboard.
b. Vertical
i. < 750mm above the ground 15deg above and 5deg below horizontal.
ii. Otherwise 15deg above and below horizontal.
I can't understand what/where these are taken??
theduck
posted on 4/4/14 at 08:00 PM Reply With Quote
Page 186 of latest pdf
Or
Section 23 page 2 of 4 if printed
theduck
posted on 4/4/14 at 08:03 PM Reply With Quote
Must type faster...
The side repeaters can be at any height and on the outer edge if cycle wings is ideal as generally this is widest point of car.
Steve,
a. Horizontal
b. Vertical
All this to come too....
The Black Flash
posted on 4/4/14 at 09:37 PM Reply With Quote
Outside edge of front wings is fine.
renetom
posted on 5/4/14 at 06:39 AM Reply With Quote
repeaters
Having failed iva the 1st time round
Mr IVA man told us to put them here.
Passed fine second go.
indicators
indicators
good luck.
[Edited on 5/4/14 by renetom]
snapper
posted on 5/4/14 at 06:43 AM Reply With Quote
I've seen them fitted to headlight bowls and pass
I eat to survive
I drink to forget
AvonJas
posted on 5/4/14 at 06:49 AM Reply With Quote
Passed last year with mine on the outside edge of cycle wings
CosKev3
posted on 5/4/14 at 09:05 AM Reply With Quote
good luck.
where did you have them on the first test to fail please?
renetom
posted on 5/4/14 at 05:08 PM Reply With Quote
Hi
I took great pains to fit them on the front roll cage tubes
Drilling & fishing for the wires inside the tubes for neatness.
Then then bastard failed them, was I chuffed ?
Modified Yamaha airbox
Good luck
René
serieslandy
posted on 5/4/14 at 06:38 PM Reply With Quote
I wanted mine on the scuttle but couldn't due to the angles. 5deg out was fine but the 5deg down meant that the arch was in the way.
I ended up putting Button 12v Amber LED CLEAR Side Indicator light/Repeater/kit car westfield/dax in the arches but removed the rubber bits.
If you do put them in the arches they must be a maximum of 2.6m from the front of the car.
HTH, Steve
[Edited on 5/4/14 by serieslandy]
DavidW
posted on 6/4/14 at 05:58 AM Reply With Quote
I passed IVA with them on the outside edges of the front cycle wings.
SteveWallace
posted on 6/4/14 at 07:10 AM Reply With Quote
Whilst I didn't pass my IVA on Friday, he had no problem with where I put my LED side repeaters as shown in this picture. They only test the angles with the wheels pointing straight forward so as long as you position them so that the 5 degree angle to the rear clears the rear arches at their widest point you should be fine.
By the way, don't use chocolate block connectors. I used them in a couple of places and it would have been a fail had he not let us change them on the day.
dunk3
posted on 6/4/14 at 07:16 AM Reply With Quote
I put mine on the side of the front cycle wing and passed IVA with no probs. some pics in my archive under mk indy full view.
[Edited on 6/4/14 by dunk3]
loggyboy
posted on 6/4/14 at 07:54 AM Reply With Quote
Hi
Good luck
René
On what basis did he fail them?
Mistral Motorsport
renetom
posted on 6/4/14 at 08:08 AM Reply With Quote
He failed them on front visibility, I then suggested small aly shrouds, he said no
Then said the radiuses were borderline.
Basicly he did not like them there, & whatever he was going to fail them.
I feel sure that another place & time they would have passed.
But what the man say's goes,
CosKev3
posted on 6/4/14 at 08:21 AM Reply With Quote
From what I've seen/read on here the side repeaters don't get checked for visibility from the front?
Steve Wallace's Viento has them on the rear face of front cycle wings, and it didn't fail on them Friday just gone.
neilp1
posted on 6/4/14 at 07:10 PM Reply With Quote
Guys thanks for the replies. I have now fitted them to the outside edge of the front cycle wings.
