Author: Subject: Tiger avon cycle wing fitting
jossey
posted on 13/4/14 at 08:17 AM Reply With Quote
This may seem silly but fitting my cycle wings when I bolt them to the uprights they touch the wheel...
Is this normal?
What's the best way to space it away from the wheels?
Washers?
Hollow tube to thread the bolt through?
Something else?
David Johnson
Smoking Frog
posted on 13/4/14 at 08:57 AM Reply With Quote
No, not normal. What size wheel (including offset) and tyre are fitted ? It may be possible to elongate the hole in the bottom bracket which has the effect of moving the top of the stay in or out. A picture may help showing where it's touching.
jossey
posted on 13/4/14 at 10:58 AM Reply With Quote
Not sure of the offset I think 35 but the cycle wings came off a tiger :-(
I'll take a pic when I go out this pm
[Edited on 13/4/14 by jossey]
David Johnson
andy350z
posted on 13/4/14 at 05:27 PM Reply With Quote
If you are using the Tiger cycle wing stays you will need spacers to move them away from wheel.
neilp1
posted on 13/4/14 at 05:57 PM Reply With Quote
David,
I used 15mm tube spacers made form stainless instrument tubing, then bend the tubes in or out for your wheel offset.
jossey
posted on 13/4/14 at 05:58 PM Reply With Quote
Thanks peeps :-)
David Johnson
