Author: Subject: Old carb filter hole in bonet!
MP3C
posted on 15/4/14 at 12:37 PM Reply With Quote
Hi guys,
Got a problem and after weeks of thinking how to do it i have come up blank. I have upgraded the engine in my car over winter and taken the standard carb off and put twin Webers on. This has left me with a nice round hole in the top of my bonnet. Does anybody have a good idea how to hide this or turn the hole into a nice shape and put some aluminum mesh under. I am a bit limited due to it being a Tiger Cat E1 bonnet and there being a nice bulge in the center of the bonnet.
Any ideas?
Thanks,
Matt
Not Anumber
posted on 15/4/14 at 12:48 PM Reply With Quote
A stainless steel or anodized aluminium plate almost the same size as the hole, held in place by fibreglass matting underneath. Black mastic in the gap.
MP3C
posted on 15/4/14 at 01:13 PM Reply With Quote
I had thought of something like that, however I'm still contemplating the idea as it will give the car sort of battle scar effect. I never thought how to secure it in so thanks for that
Matt
daveb666
posted on 15/4/14 at 01:17 PM Reply With Quote
To turn the hole into a shape simply cut with a dremel or similiar. Once you have the shape, replicate onto some 5mm MDF.
Sit your mesh over the MDF template and hammer down the edges. The mesh should sit flush with the top of the bonnet and not leave a 'cut-edge' showing.
Mount the mesh underneath the hole and attached using sickaflex or similiar,
MP3C
posted on 15/4/14 at 01:25 PM Reply With Quote
Like the idea of that! I would like a design mirrored on the opposite side as well to make it sort of uniform. However this is the point at where I am stuck... trying to design something from a circle. I am a building surveyor so my artistic side is somewhat lacking
Like the idea with the MDF though!
Matt
19sac65
posted on 15/4/14 at 03:45 PM Reply With Quote
Do tear drop like the nostrils on fw westfields
Or can you fit a scoop
Failing that fill the hole and carbon wrap the bonnet so you dont have the hassle of colour match
gremlin1234
posted on 15/4/14 at 07:21 PM Reply With Quote
use the old k&n filter top as the plate
posted on 15/4/14 at 07:36 PM Reply With Quote
Had the same problem , ended up using some fibre glass matting and a very light skim of body filler before respraying the bonnet . still good after 7 years
snippy
posted on 15/4/14 at 09:08 PM Reply With Quote
Had a similar problem on a Westfield V8 when I removed the twin SU carbs and replaced them with a single central Edelbrock set up. It left me with 2 holes in the bonnet. I fibreglassed some black mesh on the under side and it looked great. A vent hole on your bonnet isn't a bad thing, it would help disperse some of the heat. Engine bays in these cars can get quite hot!
MP3C
posted on 16/4/14 at 06:35 PM Reply With Quote
Awesome, cheers for the replies guys, gives me some more ideas to play with! I will get down to the garage to measure up soonish and i will keep you all posted and show you the outcome
Matt
