Author: Subject: sierra diff oil leak
jlayton
posted on 15/4/14 at 04:42 PM Reply With Quote
hi I have a 3.38 ratio sierra rear diff, the oil seals was leaking so I have fitted some new 1's but when I removed the old I noticed that theres a lot of scoring where the seals go. so I used some sealer before I put the new 1's back in and still leaks what are my options?
cheers
jlayton
posted on 15/4/14 at 05:22 PM Reply With Quote
just double checked its not actualy leaking from the oil seals, but between the castle looking nut the drive shafts goes through and the diff housing. whats are they called? and do they have seals?
jacko
posted on 15/4/14 at 05:55 PM Reply With Quote
There are rubber O rings between the castle nut and the body of the diff
Jacko
If you remove the castle nut it will upset the diff setup and play in the cogs
[Edited on 15/4/14 by jacko]
jlayton
posted on 15/4/14 at 06:34 PM Reply With Quote
so if it upsets the diff, do I have to go and get it set back up? or will it be ok for a little while if I just fix the leak and put it back together?
cheers
Not Anumber
posted on 15/4/14 at 08:13 PM Reply With Quote
Jacko
Telling the poor bloke that helps him how ? He is looking for a solution not another problem.:-)
It may be cheaper for you to find another diff.
jlayton
posted on 15/4/14 at 08:34 PM Reply With Quote
Cheers so I definitely can't just fix the leak and just put it back in?? Will it completely destroy it.
Ben_Copeland
posted on 15/4/14 at 08:36 PM Reply With Quote
Will do if you run the oil low!
I'm on the look out for a leaky 3.38 to modify my diff ;-)
Ben
Locost Map on Google Maps
Enter Your Details Here
baz-R
posted on 18/4/14 at 08:17 AM Reply With Quote
my diff had a thread lock type selent at the spline/nut to stop the oil seeping past
it was all ford orignal and un touched on dissambly
