Poll: Engine Woes [View Results]
Fix up
Strip out and re-build
Pick up another Zetec 1.8
Change to ......
Author: Subject: Engine Woes
mad4x4
posted on 17/4/14 at 07:22 PM Reply With Quote
Engine Woes
I'm back been away for 8 Months..... anyway, Engine in my car has never really run that well its a 1.8Zetec.
Car is an MK Indy.
Would I be better re-building the Zetec or puting something else in?
never been happy with performance of Car but that may be due to never quite running right.
Main issue is always emission always way to rich regardless of what I do, Also seems to bind up when hot and "dour" to start.
HC
What fits easliy to Type 9 and gives good performance or What what will fit even changing Box ?
Scot's do it better in Kilts.
posted on 17/4/14 at 07:30 PM Reply With Quote
Change to............
BEC
That's all........
Phil
big_wasa
posted on 17/4/14 at 07:32 PM Reply With Quote
Get another zetec.
What induction do you have ?
Ugg10
posted on 17/4/14 at 07:48 PM Reply With Quote
St170 plus chestersportscars bike carb kit (depending on emissions requirements).
billy
posted on 17/4/14 at 07:49 PM Reply With Quote
Bike engine! Pah. You want to get a nice vx xe red top engine in the thing :-)
http://youtu.be/830avqyeTDs
[Edited on 17/4/14 by billy]
luego-lo-cost finished,vauxhall 16v 2.0,twin 45s de-dion rear set up
paulf
posted on 17/4/14 at 07:56 PM Reply With Quote
A 1.8 zetec should have fairly good performance, I would say that it just needs setting up correctly, if the mixture is to rich then you will loose performance and struggling to turn over when hot indicates over advanced ignition timing or poor starter motor or earth connections.I would get it on a rolling road before you decide that the engine is no good.
Paul
Car is an MK Indy.
HC
posted on 17/4/14 at 08:04 PM Reply With Quote
Yaaawwwnnn Something not quite right there, I reckon he reached about 80mph max in that clip...
Phil
austin man
posted on 17/4/14 at 09:45 PM Reply With Quote
a properley sorted 1.8 will return 180 to 190 bhp I run a 1.8 silvertop in mine and more than happy
me!
posted on 18/4/14 at 06:47 AM Reply With Quote
I'll hazard a guess that there isn't a lot wrong with the engine, it just needs setting up correctly. What induction + management are you using?
Mine is a 2.0 zetec, GSXR600 TBs and it goes like stink. I had it mapped by Bailey Performance- the top end didn't change much from what I managed to map myself but the low end driveability and mid range torque were transformed.
What makes you think it is running rich all the time? Smell or a lambda sensor of some description?
I've read hot starting can be an issue with the sierra starter on a zetec- I use a reduction gear starter which works well. Or as mentioned, your ignition advance at cranking rpm could be out.
Sam_68
posted on 18/4/14 at 07:02 AM Reply With Quote
^^^ This.
And what makes you think that swapping to a completely different engine will solve your problems? You'll just have a whole lot of expense to put yourself right back at square one in terms of setup...
hkp57
posted on 18/4/14 at 07:59 AM Reply With Quote
A visit to the scottish kit car center, Andy's bike throttle body conversion should have it singing along.
Facebook linky
Fleet
SKC Raptor R - Hayabusa
Toyota C-HR Hybrid Limited Edition
Honda VFR1200 CrossTourer
DCT
Marlin Roadster 1800
Mercedes Vito 116 Sport
scutter
posted on 18/4/14 at 09:06 AM Reply With Quote
Another vote for the ST170 upgrade.
Regards Dan.
mad4x4
posted on 18/4/14 at 01:41 PM Reply With Quote
Facebook linky
have contacted them ----- See what happens
hkp57
posted on 19/4/14 at 09:27 AM Reply With Quote
Keep us posted
Fleet
DCT
davidimurray
posted on 19/4/14 at 10:07 AM Reply With Quote
How is your engine setup? Carbs,efi?
Have you done a compression test? If that's good then prob may well be in inlet/exhaust and if you transfer to a new engine you will probably transfer the problem!
Gallery 1 http://www.facebook.com/media/set/?set=a.116893465324.130778.601005324
Gallery 2 http://www.facebook.com/media/set/?set=a.245243755324.181913.601005324&l=a9831a9319
Gallery 3 http://www.facebook.com/media/set/?set=a.440671625324.232627.601005324&l=3f0d42c523
Gallery 4 http://www.facebook.com/media/set/?set=a.490098255324.297598.601005324&l=efb083b7df
Gallery 5 http://www.facebook.com/media/set/?set=a.10150244028550325.366987.601005324&l=583fd5cd3a
Gallery 6 http://www.facebook.com/media/set/?set=a.10150550640070325.430417.601005324&type=3&l=fe779b358c
Duratec Engine Swap https://www.facebook.com/media/set/?set=a.10152527759580325.1073741828.601005324&type=1&l=40aae5e72f " target="_blank"> https://www.facebook.com/media/set/?set=a.10152527759580325.1073741828.601005324&type=1&l=40aae5e72f
mad4x4
posted on 24/4/14 at 05:29 PM Reply With Quote
Facebook linky
mmmm - There answer - " Change to emerald K6".......
