Author: Subject: Zetec inlet manifold
snowy2
posted on 20/4/14 at 06:36 AM Reply With Quote
I am not sure if this has been noted before but it occurred to me that i think Ford acquired Mazda sometime around the time it was developing the Zetec engine. If that was so why wouldn't they raid the parts bin for engine peripherals to aid the development process?
Maybe they did, maybe they didn't.......
but since i had a Mondeo Zetec engine waiting for my next engine swap (Pinto 2.0L to go on ebay when it happens) and a Mazda MX5 i thought why not look and see?
so i bought a laser cut steel inlet manifold plate and offered it up to my MX5 inlet manifold.
as you can see there is an almost exact match..... a little work with a Dremmel and the ports will be a smooth match.....
You can also see that the Mazda inlet manifold will fix to the adaptor plate without interfering with the Zetec manifold mounts.
this will hopefully give me a better breathing inlet than the Ford plastic horror, i just have to keep the injector mounts and all should be well, hopefully figuring out the various sensors wont give me any unexpected hassles.
sometimes you are the pigeon, most of the time the statue.
Ugg10
posted on 20/4/14 at 07:42 AM Reply With Quote
Good find, thanks. Know there are a few rover t series manifold mods but the mazda one must be easier to source.
posted on 20/4/14 at 08:01 AM Reply With Quote
Yep, Rover turbo manifold matches up, only the bolt holes are different. But easy with a 1.8 zetec injector plate.
[Edited on 20/4/14 by coozer]
big_wasa
posted on 20/4/14 at 09:06 AM Reply With Quote
I tried a Rover T series Turbo mani and it was miles out. Took no end of blending. That looks much closer.
redturner
Senior Builder
Posts 449
Registered 9/11/12
Member Is Offline
Photo Archive Go!
Building: Run 2 ltr Black Top in single seater race car.
posted on 20/4/14 at 11:46 AM Reply With Quote
The Zetec ports also line up with the X flow ports as well. For a short time I used the 32/36 carb on my Zetec using a similar set up.....
