Author: Subject: Removing a broken caliper bleed screw
carlknight1982
posted on 21/4/14 at 12:54 PM Reply With Quote
Managed to break the bleed screw in swmbo rear caliper
Any tips on removing it ?
Logic will get you from a A to B
Imagination will take you everywhere.
View User's Profile E-Mail User View All Posts By User U2U Member This User Has MSN Messenger
posted on 21/4/14 at 01:00 PM Reply With Quote
Get the mig welder out and weld a nut on
carlknight1982
posted on 21/4/14 at 01:15 PM Reply With Quote
Broken off flush and I don't think it's steel
llionellis
posted on 21/4/14 at 01:33 PM Reply With Quote
It probarbly is some kind of steel. I have done the following a couple of times and it worked for me. Get or make a largish washer that will fit over the broken nipple, weld the washer to the nipple. Get a suitable nut and weld a couple of flats to the washer. Unscrew the offending nipple out.
posted on 21/4/14 at 01:57 PM Reply With Quote
Unless you really really need to remove it leave it be.
There are ways to air out of callipers without opening the bleed nippple.
[I] What use our work, Bennet, if we cannot care for those we love? .
benners05
posted on 21/4/14 at 02:07 PM Reply With Quote
have you tried a stud extractor like these?
http://www.machinemart.co.uk/shop/product/details/cht123-screw-extractor-wrench-set
Ben
loggyboy
posted on 21/4/14 at 02:44 PM Reply With Quote
This happened to me on my clio, I tried heat, cold, even complete removal and screw extractors, drillin, tapping. All failed so I ended up getting a new (used) set of callipers.
posted on 21/4/14 at 02:58 PM Reply With Quote
Use electrolysis, and after the pixies have done their magic overnight it will come out easy with a stud extractor.
My 20 year old Range Rover calipers looked like scrap and I was eyeing the bleed nipples with a sinking feeling, however electrolysis did the trick, everything came apart easy as...
SteveWalker
posted on 21/4/14 at 03:40 PM Reply With Quote
Another question is how much is a replacement caliper?
I recently broke a bleed nipple after fitting a new master cylinder to my kit-car. I tried welding to it, no luck. I tried helicoiling it and got no seal (it may be that the replacement nipple was too short or that the seat was damaged).
I happened to look on Ebay and saw that Sumo was selling remanufactured calipers for 30 each. I decided to replace the pair, but couldn't find how to combine the postage for express delivery, so I phoned and got the pair on next day delivery for 50 total!
Fatgadget
posted on 21/4/14 at 05:10 PM Reply With Quote
..Such as?
posted on 22/4/14 at 08:28 AM Reply With Quote
..Such as?
You can get a banjo connector with a built in bleed point or bleed it via the union if it will open. There are kits such as the Fraser Brown nipple therapy ones to replace the nipple link.
