Author: Subject: Speedo Cable Woes
AndyGT
posted on 23/4/14 at 09:48 PM Reply With Quote
Speedo Cable Woes
Sorry if this is in the wrong section but I thought it was the closest...
I need a speedo cable with the two ends from two different cars. So does anyone know of a supplier of custom speedo cables?
nothing is impossible
everything is possible
old_timbo
posted on 23/4/14 at 10:03 PM Reply With Quote
Speedy Cables http://www.speedycables.com/cables.html
They made up a custom cable to the length I required. Ford Type 9 one end, classic Smiths the other. I also got a 90 degree drive from them which made a neat cable run up the transmission tunnel possible.
benchmark51
posted on 24/4/14 at 06:47 AM Reply With Quote
I need a right angled drive for a type 9 box, how much was yours? Couldn't find one listed on their site.
redturner
Senior Builder
Posts 449
Registered 9/11/12
Member Is Offline
Photo Archive Go!
Building: Run 2 ltr Black Top in single seater race car.
posted on 24/4/14 at 07:49 AM Reply With Quote
Speedograph Richfield in Nottingham will make any cable you want. They have been producing cables for over a 100 years so know what they are doing.....
paulf
posted on 24/4/14 at 03:41 PM Reply With Quote
I made mine by using a sierra outer cable to attach to the gearbox and then cut it in half and used an MGB outer cut in half to attach to the speedo, I joined the 2 halves with some fuel hose and jubilee clips, I think the inner was from a mk 3 escort.
Paul
