Author: Subject: Recommend me a pre-pump filter
TrophyJem
posted on 29/4/14 at 06:02 PM Reply With Quote
I want to put a fuel filter before my low pressure fuel pump, but space is at a premium so I'm looking for a small one.
Any recommendations?
The idea is that the plumbing will go;
Fuel tank
Filter
Low pressure pump
Swirl pot
High pressure pump
High pressure filter
Fuel rail
Regulator
turbodisplay
posted on 29/4/14 at 06:12 PM Reply With Quote
Get a facet pump, in built filter. Can be slightly noisy though.
posted on 29/4/14 at 06:35 PM Reply With Quote
I had problems with the filter on my Facet pump and have converted to the small disposable fuel filters , the one with a 6mm and an 8 mm inlet /outlet , cost a couple of pounds
TrophyJem
posted on 29/4/14 at 06:39 PM Reply With Quote
It is a Facet pump. Its a Gold Flo
Does that mean it has a filter in it?
tims31
posted on 29/4/14 at 06:53 PM Reply With Quote
Got one of these in mine
UNIVERSAL 10MM 3/8 CHROME &' GLASS INLINE FUEL FILTER - PETROL &' DIESEL
small and you can see whats in it
Build: http://www.martinsfurybuild.co.uk/
mark chandler
posted on 29/4/14 at 07:32 PM Reply With Quote
That's what I have, just the job as you can see the rubbish and clean it.
greed1
posted on 29/4/14 at 07:48 PM Reply With Quote
I had one of the facet bolt on type filter for all of two miles fuel was all but blocked from it. So went for a cheap Halfrods plastic one like mr rusty nuts so far so good 200 miles and two sprints
Drive it stright sideways
