Author: Subject: Yamaha R1 (4C8) Wiring Test - Check my video.
TimC
posted on 3/5/14 at 10:28 AM Reply With Quote
Hi All,
I've got my significantly re-hashed wiring (have combined the bike loom with a CBS wiring module) to the stage where I can test 'Ignition On'.
Could anyone with experience of owning a fly-by-wire R1 engine/bike please let me know if this looks normal?
To Youtube...
Thanks,
Tim
Kev99
posted on 3/5/14 at 03:23 PM Reply With Quote
Hiya Tim
I sounds the same as mine so i would say its OK
My 4C8 has been in for 3 years with no problems just remember to do the breather mods and sump baffle plate
I also kept the ex/sup servo etc intact
Kev..........
PS
if using on track i had to add an oil separator from the crank case breather to stop it breathing to much but was never a problem on the road
TimC
posted on 3/5/14 at 03:47 PM Reply With Quote
Originally posted by Kev99
Hiya Tim
Kev..........
PS
Kev,
I was hoping you'd answer - thanks very much. That makes me very happy. I have the baffle plate fitted, the EXUP servo is still connected and the breather mods are done. I'm absolutely planning to use a separator too. What does yours look like?
Thanks again,
Tim
Kev99
posted on 3/5/14 at 04:03 PM Reply With Quote
This is the one i used in the end NEW OIL BREATHER SEPERATOR PINTO CATERHAM WESTFIELD V8
Was looking for something a little nicer but didn't find anything
U using an air box or is that a base plate i can see in the video any pics would be welcome
TimC
posted on 3/5/14 at 09:14 PM Reply With Quote
It's an ITG/Reverie 'trumpet tray' that's been modified with some additional carbon work by Dave at Track Developments. At the moment I'm using a standard JC50 filter but depending on noise and performance I may later upgrade to Reverie's top-section. However, it's not far off £400 even in GRP so trying to avoid it.
This one was taken today - I've just added a cable-tie base to help support the oil breather pipe.
jelly head
posted on 4/5/14 at 08:17 AM Reply With Quote
Yeah sounds exactly like mine as well.
TimC
posted on 4/5/14 at 11:31 PM Reply With Quote
Thanks - good to know.
