Author: Subject: Silver top zx6r carbs on three cylinders ??
dan8400
posted on 7/5/14 at 08:09 PM Reply With Quote
Hi everyone
On Saturday morning my Tiger went down to three cylinders. Was only popping out so came home and got the tin top. I have since changed the plugs and leads (gapped plugs etc).
The car seems to tick over on four and rev on four but when under acceleration (especially mid to high revs) it drops to three. Is this an ignition problem? Ie coil pack going down? Or a fuelling issue. I am not sure what to try next
Any suggestions welcome
Dan
Hey - That's Journey!!!
avagolen
posted on 7/5/14 at 08:33 PM Reply With Quote
I would have a look at an air leak around the offending carb or a blocked jet.
You could try spraying WD40 around the inlet manifold and see if the revs change.
If not then I would give the carb a deep clean with some carb cleaner.
What are you using to connect the carbs to the manifold, are all connections still secure?
Just my random thoughts.
dan8400
posted on 7/5/14 at 08:36 PM Reply With Quote
How does the wd40 help? Will it show up an air leak?
Good idea on carb cleaning. Am I best off removing them and disassembling them / cleaning them on a bench?
Dan
dan8400
posted on 7/5/14 at 08:37 PM Reply With Quote
Are there any easy ways to clear blocked jets anyone??
avagolen
posted on 7/5/14 at 08:45 PM Reply With Quote
From what I hear, if there is an air leak, spraying with WD40 raises the revs as it sucks in the propellant etc.
I stripped my carbs and soaked them in carb cleaner and sprayed all holes/jets/bits with it as well.
(one at a time making sure I did not get the bits confused/lost etc)
It definitely made mine run better. Make sure you check how far out the air bypass screw or what ever it is
called is before you start - screw it in gently noting the turns required until it stops.
(located at the engine end of the carb underneath)
HTH.
19sac65
posted on 8/5/14 at 03:52 AM Reply With Quote
Are you using a ford coil pack
They can give that symptom
dan8400
posted on 8/5/14 at 04:31 AM Reply With Quote
Yes. It's the one that came with the engine. Are they expensive? I have another old one lying around. Will try that for comparison
Dan
davidimurray
posted on 8/5/14 at 08:14 AM Reply With Quote
Have you checked the balance on the carbs?
Does it only run on 3 when you are accelerating or when cruising?
Gallery 1 http://www.facebook.com/media/set/?set=a.116893465324.130778.601005324
Gallery 2 http://www.facebook.com/media/set/?set=a.245243755324.181913.601005324&l=a9831a9319
Gallery 3 http://www.facebook.com/media/set/?set=a.440671625324.232627.601005324&l=3f0d42c523
Gallery 4 http://www.facebook.com/media/set/?set=a.490098255324.297598.601005324&l=efb083b7df
Gallery 5 http://www.facebook.com/media/set/?set=a.10150244028550325.366987.601005324&l=583fd5cd3a
Gallery 6 http://www.facebook.com/media/set/?set=a.10150550640070325.430417.601005324&type=3&l=fe779b358c
Duratec Engine Swap https://www.facebook.com/media/set/?set=a.10152527759580325.1073741828.601005324&type=1&l=40aae5e72f " target="_blank"> https://www.facebook.com/media/set/?set=a.10152527759580325.1073741828.601005324&type=1&l=40aae5e72f
dan8400
posted on 8/5/14 at 08:20 AM Reply With Quote
It does it on both. Mid to high revs
mcerd1
posted on 8/5/14 at 09:26 AM Reply With Quote
^^ easystart works a bit better
you just mist it around the inlet manifold etc (not into the air filter or anywhere that air is meant to get sucked in)
and if there is an air leak close to where you sprayed it will get sucked in and the engine will rev up a bit
davidimurray
posted on 8/5/14 at 09:32 AM Reply With Quote
It is unlikely to be the main jets as they have quite a big opening. The pilots are tiny holes and blowing through doesn't neccesarrily clean them. I found that the best was to clean was to remove pilots and soak in carb cleaner overnight. Wouldn't hurt to do mains at thes same the and they you have a good base to look for any further issues.
dan8400
posted on 8/5/14 at 09:45 AM Reply With Quote
Ok. Thanks for the replies.
This gonna make me look like a noob but how do I remove the jets?
Zx6r carbs
I am off to buy a new coil pack for the car too. Might as well eliminate everything. Already changed plugs and leads
Dan
davidimurray
posted on 8/5/14 at 07:09 PM Reply With Quote
Zx6r carbs
Dan
No worries, done mine loads of times now and I can do them blindfold
Step 1 - Put some rubber tube over the float bowl drain into a jar, then undo the screw and drain the fuel out of the carb. Do this for all 4. After this do not turn the ignition on or you will fill them back up! Don't forget to close the drain screws
Step 2 - Remove the float bowl. There are 3 screws, 2 at the engine side and 1 in the middle at the air filter side. With the carbs on the carb the screws will be facing upwards. If you have the original kwak screws I strongly suggest you change them for some cap heads as the originals are made of soft cheese!
Step 3 - Carefully remove the float bowl, there may still be a little bit of fuel in there so be careful.
Step 4 - If the carbs are still on the car you will now be working upside down. But if you use a little mirror you should see this -
Get a flat bladed screwdriver, make sure it is a good fit in the slot and un screw the main jet and pilot jet. The pilot will be like a long tube full of holes, the main will just be a short stub, there is no need to remove the main jet holder.
Step 6 - Remove all 4, fill a glass (don't use anything plastic) and chuck all the jets in there for 24 hours. While they are in there give a spray up the jet passages.
Step 7 - as the Haynes manual says, reassembly is the reverse!
[Edited on 8/5/14 by davidimurray]
dan8400
posted on 8/5/14 at 07:33 PM Reply With Quote
Thank you for that description David. Excellent advice and a brilliant step by step.
I feel confident to have a go at this now
Dan
Btw my new coilpack arrives tomorrow so that is another thing eliminated
[Edited on 8/5/14 by dan8400]
Paul W
posted on 5/4/15 at 09:12 PM Reply With Quote
Dan did you fix this problem?
