Author: Subject: Another Garage Clear out... Pinto
hearntd
posted on 26/5/14 at 10:30 AM Reply With Quote
So I finally decided I was fed up with tripping over my old Pinto and a few other bits in the garage so time to get rid, the list of items I have and a couple of pics below.
1, 2.0 205 block Pinto, this is a complete engine (came out running) it has the following with it:
Twin Webber 45's, throttle linkage and cables.
FR32 fast road cam with vernier pulley.
Bestek electronic ignition kit.
Shortened and Baffled sump
Alternator
Starter
and cooling hoses.
Currently has tiger engine mounts.
The engine was Rolling roaded before I fitted the new head and cam @120BHP and 133lbs/ft.
2, Type 9 5 speed gearbox with Pinto bell-housing, this was with this engine, never had any problems with it.
3, I have the Pinto headers form tiger (no picture).
4, RWD Type 9 to Duratec bell-housing, this is the cable or hydraulic one, it has both the cable arm with a modified release bearing for raceline clutch cover etc. and also a hydraulic slave cylinder with hoses. I am not sure if slave cylinder is OK but I'm throwing it in anyway.
5, Duratec engine mounts, I'm not sure what car they are for but I think Westfield...
I'm open to sensible offers on any of this. Oh and I'm in Hampton Middx.
1, [img]https://lh5.googleusercontent.com/vPcZXVfGRRCZwjkKhFf5iFewYUCy7g_7J6c_W8gkft9a=w334-h187-p-no[/img]
2, [img]https://lh6.googleusercontent.com/dLrpe_B8DprNdA67vEW9yYlzH35GhwpdRb2XqwepPpLc=w403-h226-p-no[/img]
4, [img]https://lh4.googleusercontent.com/VaFsWl15FRZr86G0M9GauYvBg1TdIcp1n57Vzq8Wzy3d=w116-h207-p-no[/img]
5, [img]https://lh6.googleusercontent.com/C07_OY831wHZYW-SniffwElWR7jFawf8C0BRVHNz_PDl=w116-h207-p-no[/img]
[Edited on 26-5-14 by hearntd]
[Edited on 27-5-14 by hearntd]
sjmatthews
posted on 26/5/14 at 02:37 PM Reply With Quote
Surely that's 120 BHP?
I'll be in the garage dear!
hearntd
posted on 26/5/14 at 04:34 PM Reply With Quote
Ooops Sausage fingers I've updated it now
samjc
posted on 26/5/14 at 06:50 PM Reply With Quote
The hydraulic clutch does it have a mounting plate to suit the type 9 if so im intrested.
hearntd
posted on 26/5/14 at 07:07 PM Reply With Quote
Hi, yer it has the adapter plate for the slave cylinder. I did try go to fit it to my setup (type 9 and duratec) but I have the raceline flywheel and clutch setup, so the cylinderdid not reach the cover plate.
Hope that helps.
Mattie_maries
posted on 26/5/14 at 07:52 PM Reply With Quote
Would you split the webbers off it?
hearntd
posted on 26/5/14 at 08:53 PM Reply With Quote
I'd rather keep it all together for now but I'll keep it in mind.
robinhoodman
posted on 30/5/14 at 09:48 PM Reply With Quote
pinto
Hi how much are you looking for the engine
serieslandy
posted on 30/5/14 at 10:04 PM Reply With Quote
How much for the dura tech bell housing (#4) assuming you can post?
hearntd
posted on 31/5/14 at 09:06 AM Reply With Quote
U2U sent to robinhoodman and serieslandy
