Author: Subject: Type 9 soft gearbox mount?
Shaunk10
posted on 15/6/14 at 08:19 PM Reply With Quote
Hi guys, iv basically had to organise a new propshaft etc after my old one failed, anyway after putting everything back together but without the inside panels on it so I can have a look, I noticed when I put my car in gear and almost using the geartsick as lever to deliberately move the gearbox around to check how much movement is in it. It's quite soft so to speak, with not too much force I can almost lift the gearbox up and down etc just with the geartsick. Now the geartsick has been modified by bringing it forward so it's attached to an extension piece and a ball joint (which all works well) but I'm just a little worried that the gearbox mounting is too soft? What should they be like, and should I upgrade it if possible or replace it? The standard rubber one by the looks of it.
Cheers all
bob
posted on 15/6/14 at 09:10 PM Reply With Quote
Type 9 sierra gearbox mounts are extremely soft, luckily an alternative mount can be purchased.
The harder mount is much harder rubber and a little different in width, it may also need a little refit to the original chassis area.
Ford Lotus Kit car competition gearbox mount 70 shore RWD 4 &'5 speed inc type 9
Shaunk10
posted on 15/6/14 at 09:40 PM Reply With Quote
Cheers for that, is that the thing that people often change over too then, does it have any effect on the car itself?
johnemms
posted on 16/6/14 at 07:56 AM Reply With Quote
My Sierra gear box mount had the gear stick going up & down maybe 2" over bumps...
Took it out modded it to 'firm' .. no problems .. very nice
Own chassis & Build - First time pass!!
"7's" aren't really "cars", they are 'experiences"
mcerd1
posted on 16/6/14 at 09:11 AM Reply With Quote
as above the old 4 speed style mounts are the ones you want, they were used on Cortina's, Escorts etc... but are also the standard mounts for Caterham and Westfield too (Caterham actually sell them for 13+VAT, but the website says out of stock just now )
any of this style will be a massive improvement on the sierra style mount (even the standard/non-copetition versions of the older mount) - they a lot stiffer, but also a little smaller and slightly taller (just a few mm) so you'll need to rework the brackets it bolts onto a little
here's some pics for you of the 2 types side by side:
(this ones actually from westfield, before they put the price up...)
johnemms
posted on 16/6/14 at 10:37 AM Reply With Quote
I cut all the rubber out of mine ..
made a metal cradle ..
put some 5mm silicon rubber sheet for isolation ..
bumpy
posted on 26/2/15 at 04:33 PM Reply With Quote
So which is the best one, the rounded one or the angular one?
