Author: Subject: How to stop panel vibration help :)
INDY BIRD
posted on 28/6/14 at 10:26 AM Reply With Quote
Ok hi all,
My Westfield duratec has the engine solid mounted aswell as the gearbox,
Due to this the car has a lot of vibration through the chassis and panels,
How is best to stop this and what is the best material,
And changing the engine mount no and option they are rubber bushed joints but lots of vibration,
And as it has a sequential box there's a fair bit of noise there too
Thanks and any tips welcome,
Sean
Daddylonglegs
posted on 28/6/14 at 10:50 AM Reply With Quote
If you don't mind a little extra weight, you could use some of this. I used it on our Midget as sound deadening for the floor and doors.
rdodger
posted on 28/6/14 at 11:32 AM Reply With Quote
Dynamat or similar
Have to say though wickes flashing tape is probably the best locost option
You don't have to cover entire panels in it. Small A4/A5 size pieces in the middle of large panels usually does the trick.
INDY BIRD
posted on 28/6/14 at 11:37 AM Reply With Quote
Good idea,
It's annoying and when I video in the car all the mic pics up is the high resenence of the panels vibrating drowning out the engine noise very annoying still I'll look into this any other ideas welcome
Steve ads
posted on 28/6/14 at 03:36 PM Reply With Quote
As previously mentioned dynamite will help bit pricey tho
killerferret666
posted on 28/6/14 at 05:42 PM Reply With Quote
A cheaper alternative to dynomat is silent coat, which I've put on my build.
There is a video on YouTube of the difference it makes
[Edited on 28/6/14 by killerferret666]
Building DDR GT4
Miami Gt4 Blog - Click Here
