Author: Subject: 4AGE Build
greed1
posted on 24/7/14 at 09:48 PM Reply With Quote
4AGE Build
Good evening guys and gals,
Thought it was about time I used this site and members to the full potential instead of hiding in the back ground .
Last month I bought a 1.6 red top 4age from a Toyota corolla, if all goes well I will be replacing my now tiring cross flow with this in the not to distant future.
I'd like to break 200bhp or at least 180, which doesn't sound hard according to the websites and forums dedicated to the Toyota lump.
This will be the first time I've stripped an engine past the head so I will be taking my time doing it step by step and start at the bottom up. So crank and flywheel balance and lightening first! Ive done a bit of reading on L/W flywheel's but lack of experience and knowledge has left me at a bit of a dead end. I've found anything from 2kg right to the standard 7kg flywheel, aluminium and chromoly???
My kit is mainly used for sprint races and the occasional blast round in this great weather, so I don't want it totally unusable on the road but still fast enough to keep upwith the trailered cars.
Any advice would be greatly appreciated, what are 7 style cars like to drive with lightened flywheels what weight have you used?
Photos to follow as I can't get them to upload from my phone yet.
Drive it stright sideways
bi22le
posted on 25/7/14 at 11:08 AM Reply With Quote
I have a 4age blacktop with a fernanza (sp?) Lightened flywheel and out is fine to drive in traffic. A lot easier than my old BEC.
I will be interested to see what spouses of information you tap into and where you get your parts from as I hope to be doing similar work in the next few years.
Please read my ring story:
Jed
posted on 25/7/14 at 05:08 PM Reply With Quote
I have a MG Midget with a bigport 4A-GE 16V with RM lightweight flywheel (with integrated 36/1 trigger wheel) and matching bell housing to mate to a type 9. The 4A-GE 20V ITBs are mounted on one of those cheap & heavy Taiwan made steel inlet manifolds that can be found on ebay but I picked mine s/h and much cheaper. The flywheel is 4.9Kg and I don't have any issues with pulling away at low revs in a 700Kg car and think you'd be OK going lighter still.
I have no idea what power mine is putting out because I've only just built it but I'd be interested to see how you get on. I expect that >180bhp is going to get expensive.
Jed
Canada EH!
posted on 25/7/14 at 05:12 PM Reply With Quote
Super light flywheels on a 4 cylinder engines can lead to rough idle as one of the functions of the flywheel is to keep the engine spinning at low speed.
One other function is to assist with the take up of the clutch from idle to starting the vehicle rolling- light flywheels tend to cause more stalling from start, not a problem in race setup but a problem in traffic.
For street use I would not go less than 2/3rds stock flywheel weight.
greed1
posted on 25/7/14 at 06:00 PM Reply With Quote
Hey is it the 'fidazan' (aluminium flywheel) you have bizzle? I almost ordered one the other day before I posted on here. But now I've looked in to them a bit more and I won't be using one of those lots of people having issues with the ring gear coming loose and some only after a year .
I had thought that 2kg was going to be to wild for road use but had to mention it as looks amazing bet it gets a bit hot
I apologise now if the PIC is to big hard to change much from my phone
So somewhere between 4-5 kg will free up the revs and still be usable on the road although I don't think I've hit 1000 miles this year and certainly not any traffic in those miles.
Think your right Jed I was just going to run it standard but now I've striped it and started looking for bits I can't stop myself now now planning to inject it when I get towards the end. Did you buy your flywheel direct from richard macer if so do you have his contact/website?
[Edited on 25/7/14 by greed1]
Jed
posted on 25/7/14 at 08:56 PM Reply With Quote
I don't have any contact details for Richard and couldn't find any valid details either. I picked up my bits mainly from PH or ebay.
luke2152
posted on 25/7/14 at 09:09 PM Reply With Quote
One thing to bear in mind is its not just the weight of the flywheel but the design (rotational inertia) - if most of the weight is on the outside it may be light but behave more like a heavier one or vice veras
bi22le
posted on 26/7/14 at 02:46 AM Reply With Quote
It came with the car. I don't know what style it is. I have had the car for about 5 tears and have had no trouble. I don't know what it weighs off of the top of many head but I do have the details at home.
Forgot to mention that the UK Driftworks forum it's a great source four 4age information and SH parts. I picked up a stump for 10quid. They are 3x that if you are lucky to find one
[Edited on 26/7/14 by bi22le]
greed1
posted on 4/8/14 at 08:47 PM Reply With Quote
about time for an update i think
i have now striped the engine which took longer than i had planned due to one small pulley Description
bloody thing held tight for four hours until i got the angry grinder out, at least a new one is only £18 from Toyota.
apart from the obvious above the engine looks to be in good condition only found one score mark on the big end and hardly anything on the crank of course i dont know for certain until someone with the right tools looks over it.
A couple of new shiny bits have arrived from TTV racing excellent service form these guys ordered/payed at 3pm and it arrived next day.
the flywheel comes in at 3.4kg roughly half the weight of the original and the pulley 660g, 1 kg lighter than standard and more importantly has the 36/1 teeth. i know this is going to make hard going for the road but think it will be worth it once im used to it.
ive also done a bit of work to the combustion chamber in the head, following Lag Lag Lag's post here. http://forum.twincam.org.au/topic/2936-diy-porting-your-16v-4age-head/
this is what i started with
Combustion chamber
Combustion chamber
and took it slow with the dremel
only removed the sharp spots in the chamber to reduce the chance of pre ignition when the compression is upped. i am too chicken to touch the ports so will leave this for a pro to do once i find one (any recommendations).
a set of cams turned up on the bay yesterday, newman's ph4 profile new with adjustable cam pulleys for £350 i couldnt turn it down.
few more things still on the list i need to get like pistons, valve springs and arp bolts. these can wait for a while now as i will be getting the block and crank checked over first
edit does anyone now how to remove the centered text?? or is it just my laptop
[Edited on 5/8/14 by greed1]
bi22le
posted on 4/8/14 at 08:59 PM Reply With Quote
Keeps us up to date with the details and also the suppliers you use. Fensport is the main one I know of but they seem expensive.
Some parts I know that you can still get from Toyota but I dont know how far their parts lists span. I expect them to not do much for my import only AE111.
greed1
posted on 5/8/14 at 06:28 AM Reply With Quote
I have only found two other suppliers but I haven't used either yet, torque developments international torque developments international are the UK suppliers for Toda Racing Japan. they don't seem to carry stock of 4age bits but can get them In a couple weeks.
Also mcnsport in Ireland who have both 16 and 20v listed on there website.
From what I've been reading of Toyota if you have a part number they can get it for you, the crank pulley and oil filter I ordered came within a week so must have been in the country already but they were very helpful over the phone as I couldn't give them a number plate and i only had one part number which I wasn't sure was right.
Found my engine number yesterday or at least I think it was before the rust took hold of it I can just see a 3 on the end, does anyone know if I can make my own up to tell the dvla about the engine change?
greed1
posted on 6/8/14 at 08:17 PM Reply With Quote
After reading this Thread I won't be getting ARP head studs which will free up £150 for other goodies Still need them for the conrods and mains.
Is it generally a good idea to change oil and water pumps when doing a build to this extent.
Hopefully I can find someone on Friday who can clean engines so I can see what I am actually working with and without gloves
More to come
edthedrummer
posted on 6/8/14 at 10:01 PM Reply With Quote
I'm going to be building a 20v blacktop shortly for a friend so I am paying careful attention to this thread.
It's usually common to replace the water pump on a rebuild, usually because they are fairly cheap and often driven by the belt, so a pain to change once it's all built.
Quite often, oil pumps can be stripped down back to bare housings and rotors and then cleaned inspected and rebuilt.
If your unsure of anything during your build, feel free to u2u me and pick my brains. I'm a competition engine builder by trade so I may be able to help.
Ed
greed1
posted on 12/10/14 at 07:50 PM Reply With Quote
Sorry for the slow update all,
Pistons arrived shortly after my last post
pistons
pistons
The block has been sent away for machining same with the head, although I did order a set of supertech valve springs and cam followers with under bucket shims just to be safe and future proof the engine if I find I need more lift later on.
While I can't do anything on the engine at the moment I set about painting the rocker covers with wrinkle paint,strange stuff to work with but didn't turn out to bad. I needed bit more paint on the sides as they didn't wrinkle as much as the top.
Also decided to go for a long first gear in my type 9 so started to take it apart this weekend. I couldn't find a 36mm socket locally so 5 gear is as far as I got. Does anyone have any experience with any of the long first gear kits and any recommend. Burton appear to have both 2.98/1 and 2.74/1 for the 2l type 9 but over £100 between them
