me!
posted on 25/7/14 at 04:16 PM |
Sylva Stylus For Sale - £3.5k
Not sure how I feel about doing this, but here we go....
Early Sylva Stylus 'Classic', I believe the chassis was supplied in 1992, and it was SVA'd in 1998 on a donor T reg. Being an early
one the frame is a modified Fury chassis as far as I can work out.
I purchased the car in 2012 (I think!) with a 1.3 X flow fitted. Since then it's had quite a bit of work, I've fitted a Blacktop Zetec on
GSXR throttle bodies, Procomp supplied Protechs have replaced the ageing SPAX, I've re-done the dash and had a bit of a tidy up.
The engine is an ebay special so I don't know the history, but I had the head off. Bores looked good, had a bit of a tidy up, new head gasket,
valve stem seals, lapped the valves and brought the valve clearances back into tolerance with new shims. New water pump and gates cam belt kit went on
when it was re-assembled. The sump is a standard blacktop one modified by strontium dog on LCB for better ground clearance. Bogg Bros manifold which
is a bit unique in that it takes the ST170 injectors in the standard Ford location with a Focus fuel rail and pressure reg. Injectors were serviced by
Mr Injector prior to fitting. Loads of other stuff to aid the change to fuel injection, modified tank, swirl pot, fuel pumps etc, R9 hoses etc.
Microsquirt ECU setup by Dale at Bailey Performance- power wasn't amazing at 156 bhp but it's got a good lump of torque and drags the car
along very nicely. Small issue with leaning out at very low throttle angles, seems to be common to motorbike TB's- I haven't had chance to
do much about it. Doesn't stop me driving it!
I had new dampers and springs supplied by Procomp to replace the long past it original SPAX. These have transformed the handling of the car. Yesterday
I fitted grease nipples into the rocker arms and filled with grease which has cured the creaking front suspension and seems to helped the ride and
handling a little- this seems to be common on this design on Sylva suspension!
For pics have a look in my for sale folder here: http://www.locostbuilders.co.uk/photos.php?action=gal&user=me!&folder=For%20Sale
Why £3.5k? I didn't really know how to price it. It's not finished, but it is registered, taxed, and MOT'ed. Unfortunately I
don't get much spare time to play with it, the wife won't sit in it much further than the local pub as it messes up her hair, so it rarely
gets used. Think of it as some fun for the remainder of the summer before tarting up in the winter and you'll have a great car for not much
cash. Hopefully the price seems fair- I've set it lower than I originally intended hoping to rouse some interest. I don't want to accept
offers at this price- it's £3.5k or I think I'll keep it as an occasional Sunday toy!
If you are interested drop me a U2U and I can give more details, pics, etc.
Thanks for looking.
Craig
ian locostzx9rc2
posted on 25/7/14 at 04:38 PM |
Sounds like a bargain to me won't be on here for long
jacko
posted on 25/7/14 at 05:05 PM |
Too cheap
£ 4.300 is what it should be put it on piston heads
[Edited on 26/7/14 by jacko]
adithorp
posted on 25/7/14 at 06:26 PM |
Giving it away at that price, especially while summers here.
I'd edit quick before everyone sees it.
http://jpsc.org.uk/forum/
me!
posted on 25/7/14 at 07:13 PM |
Thanks for the comments. It'll go on pistonheads for a touch more tomorrow, but only enough to 'barter' back to £3.5k. I've
seen too many cars advertised for months on here/PH only to bump with 'now accepting offers at £XXXX'. Hopefully someone will get a
bargain, I'll have lost money but I didn't buy it as an investment, I've learnt a crap load off you lot and enjoyed owning it. You
can't put a value on that!
Ety
posted on 28/7/14 at 06:39 PM |
Defo too cheap. Pistonheads get great coverage. Sold a few cars on there, used to be free to advertise. Good luck.
me!
posted on 31/7/14 at 09:38 PM |
Finally got round to advertising on Pistonheads. Fingers crossed.
http://www.pistonheads.com/classifieds/used-cars/kit-cars/sylva/sylva-stylus-2-0-zetec/2677227
DIY Si
posted on 1/8/14 at 09:39 AM |
I don't suppose you'd swap it for a 51 plate 330i Touring would you?!
And damn you for tempting me with a cheap Stylus!!
Sun Tzu, The Art of War
me!
posted on 1/8/14 at 10:28 AM |
I've already got a 51 plate 325i touring, I'd be more tempted by a V6 sprite!
At this price you may as well buy it, tart it up and sell it for £1k more next spring ;-)
me!
posted on 2/8/14 at 03:31 PM |
Deposit taken
garyo
posted on 4/8/14 at 04:36 PM |
Damn - need to spend more time on the forum so that I don't miss things like this!
