r1_pete
posted on 15/8/14 at 09:04 AM |
Low Pressure pumps in Swirl pot injection setups
What low pressure pumps are people using in injection swirl pot setups?
It would seem the norm is for them to run constantly, which my present SU type interrupter pump isn't designed to do, I had thought of fitting a
float system to shut off flow, but thought I'd ask first how others are doing it. Does a restrictor in the return help etc. etc.....
Cheers.
Pete.
big_wasa
posted on 15/8/14 at 09:31 AM |
If you restrict the return to the tank from the swirl pot there should be enough resistance for your su pump to stop and start but also allow air /
bubbles /some fuel back to the tank.
SPYDER
posted on 15/8/14 at 09:49 AM |
I used a run-of-the-mill high pressure pump pushing through a 1mm restrictor to keep the auxiliary tank full. No problems so far. Apart from
forgetting to switch it on. Doh!
NigeEss
posted on 15/8/14 at 12:42 PM |
I used a small facet type pump wired into same circuit as the HP pump so they both run together.
The return from the injection rail goes back into the swirl pot and a large bore overflow takes care
of any excess. No problems so far.
mark chandler
posted on 15/8/14 at 05:38 PM |
Little facet pump for me also, I have a restrictor in the return so it clonks over slowly once the air is dispersed
neilp1
posted on 17/8/14 at 10:39 AM |
I use a facet red top.
sebastiaan
posted on 17/8/14 at 11:03 AM |
That's clever. How big is the restrictor you are using?
