Author: Subject: tyre pressures
kentmagpie
posted on 16/8/14 at 10:37 AM Reply With Quote
tyre pressures
Hi guys, just wondering what the correct tyre pressures would be on the indy busa. It's running 205/50/15's. Just for fast road use. Thanks in advance.
twybrow
posted on 16/8/14 at 10:49 AM Reply With Quote
I use 18 psi on my BEC, which uses 13" wheels/tyres front and rear. Most people will be using somewhere between 16-22psi - try a few pressures and feel for the difference.
kentmagpie
posted on 16/8/14 at 11:05 AM Reply With Quote
Thanks, should I use the same psi front and rear or have the back slightly more?
