MBrown
posted on 22/8/14 at 11:53 AM |
Mounting points for seats
Hi all, couldn't find anything/any pics about this but I am at the point of deciding how to mount my seats to the chassis.
I have bought seat runners as I want to be sure I can adjust the seat but I am making the haynes chassis and in the book it doesn't show any
mounting points. What have people done to fix the seats to the chassis? Any pics to show the design of the box section/metal plate mounting points
would be greatly appreciated.
Stot
posted on 22/8/14 at 01:19 PM |
I welded in some 25mm x 3mm angle with captive nuts welded to the back. You can see below.
Stot
MBrown
posted on 22/8/14 at 01:58 PM |
Thanks stot, that looks like a light weight and simple way to do it, I haven't got the seats yet so don't know how far back/forward to
position them, it looks like the rear mounting on yours is about 30cm from the back of the cockpit, when you fitted the seat do you have to have it
slid back on the slider much? Hope this makes sense, mark
Stot
posted on 22/8/14 at 02:29 PM |
I pulled the runners out enough so that I could screw a bolt down past the front of the seat, positioned the seat with the back touching the back
panel and put the front support where the bolt hole was. The back support position then just measures off your runners.
Stot
MBrown
posted on 22/8/14 at 02:54 PM |
Perfect that all makes sense, I'll steal your idea if you don't mind! Thank you
serieslandy
posted on 22/8/14 at 05:32 PM |
I did mine in a similar way, 3mm strip 40mm wide for the runner and 25mm box for the pas seat so it was the same height (no runner).
Tbh my runner is crap and doesn't really work very well but is better than nothing and I have the seat all the way back.
[Edited on 22/8/14 by serieslandy]
MBrown
posted on 23/8/14 at 07:56 AM |
That would mean I could sell one of my runners and recoup some money, thanks for the help ppl
