<<  3    4    5    6    7  >>
New Topic New Reply
Author: Subject: mk SR20DET build
mk85
posted on 7/12/15 at 10:19 AM Reply With Quote
The dash was next but will need to be redone at some point as I made a small tear in the material just as I finished.
mk85
posted on 7/12/15 at 10:23 AM Reply With Quote
Fitted the carbon wind breaker
mk85
posted on 11/12/15 at 07:48 AM Reply With Quote
I drilled and set my dash out ready to be wrapped. I've got a water temp sensor to the left. The centre gauge is for the Speedo and mileage counter. It's a nifty but of kit that has lots of indicators built in for my headlights, indicators oil pressure and more.
mk85
posted on 25/12/15 at 01:46 PM Reply With Quote
The carbon wrap i had purchased for the dash wasn't as i liked so i ordered afew samples i decided on a new vynal. I even managed to do this in the living room with the wifes hairdrier!!!!!!!!!!!!!!!!
Cut to size from the roll
peeled and placed onto the dash
Clocks and switches fitted
mk85
posted on 25/12/15 at 01:47 PM Reply With Quote
A little video of the clocks wired up
[IMG]http://i63.photobucket.com/al bums/h131/munroshaun/Mobile%20Uploads/2015-12/th_VID_20151224_164801_zpsmf35ri7f.mp4[/IMG]
mk85
posted on 29/12/15 at 10:47 PM Reply With Quote
just about have the dash ready to fix into position just a few little bits to sort before its fixed into place. Really made up with the finish and outcome. Overall it cost me roughly 25quid to make and wrap myself in a carbon finish wrap. I need to trim the excess vynal from the grey wrap and reheat one side as it has lifted slightly.
Tried the carpet i have chosen on the top tunnel and made up with the colour and feel of it.
mk85
posted on 29/12/15 at 10:50 PM Reply With Quote
better view of the dash
mk85
posted on 3/1/16 at 09:11 PM Reply With Quote
after trying a sitting in the car a few times and knowing how i like to drive i decided i wanted to bring the steering wheel closer to myself. I ordered some 15mm steel pole and started with the new column.
I had a snap of boss i wanted to use so i trimmed down the flange down to a 50mm radius. I welded a 50mm flange onto the steel rod for the quick release to bolt to.
mk85
posted on 3/1/16 at 09:15 PM Reply With Quote
Just waiting for some bearing to arrive so i can get this mounted.
mk85
posted on 3/1/16 at 09:20 PM Reply With Quote
Knowing the engine and how the like to kick some heat out once they have some energetic running I wrapped the down pipe in a heat proff wrap to help try keep the engine bay temps down.
mk85
posted on 3/1/16 at 09:24 PM Reply With Quote
Really liking the width and stance of how the car sits
DRC INDY 7
posted on 23/1/16 at 05:15 PM Reply With Quote
Sounds like it is coming on a treat, do you have any upto date progress pictures.
Puddle Dodgers Club
mk85
posted on 24/1/16 at 04:03 AM Reply With Quote
The car is doing really well. The list is very short now. Basically it's just finishing touches to get it ready. I have just rebuilt a new steering column set up bringing the wheel much closer to me.
My job list is
repair the nose cone
Refit the steering column
Mount the body panels and wrap them as I go
Trim the interior
Make my foam seat
Plate up the tunnel
Make a boot lid for the rear tub
Make some brackets for the front arches
mk85
posted on 27/2/16 at 10:50 PM Reply With Quote
Managed to get a few hours in in the car last weekend. wrapped the drivers side panel and had a little look at the finish.
mk85
posted on 27/2/16 at 10:52 PM Reply With Quote
mk85
posted on 27/2/16 at 10:54 PM Reply With Quote
Rossmcleod2012
posted on 28/2/16 at 07:35 AM Reply With Quote
Looking good mate
It's coming together
mk85
posted on 28/2/16 at 11:04 AM Reply With Quote
I picked up some hallway mats from a local hardware home shop they where only a couple of pounds each and have a rubber bottom to them so with a little spray adhesive they will hold nicely in place
mk85
posted on 28/2/16 at 11:11 AM Reply With Quote
I got the dash lined up with my side panel's and really like the silver and carbon colour combo brakes the car up nicely
Wolf1e
posted on 28/2/16 at 10:03 PM Reply With Quote
Hi mk85
Great build mate. Looking very nice. Going to be a quick one!!!
Quick question, what did you use for your boot panel pieces? Is it carbon dipped?
Wolfie
mk85
posted on 28/2/16 at 10:33 PM Reply With Quote
Hi wolf1e what panel are you referring to. The panel behind the drivers seat is just covered in fabric
Originally posted by Wolf1e
Hi mk85
Wolfie
Wolf1e
posted on 29/2/16 at 01:16 PM Reply With Quote
Hi mk85
The panel you used for the top panel where you mounted your fuel filler cap?
Regards
Wolfie
mk85
posted on 13/3/16 at 01:02 PM Reply With Quote
I purchased another nose cone with a slightly different shape to the one I had. I gave it a little clean up and started to wrap it in the vynal. After reading a review in the recent kit car magazine I followed there advice and have wrapped the nose in two sections. The bottom will be done in a separate section as to do it in one would over stretch the material
mk85
posted on 13/3/16 at 01:03 PM Reply With Quote
mk85
posted on 28/3/16 at 06:15 PM Reply With Quote
I've been really busy lately but managed to make some great progress on the car.
I've trimmed the whole drivers side with fabric and and mats in the floor. I went for a grey pattern as this over time will hide any dirt marks left behind
<<  3    4    5    6    7  >>
New Topic New Reply
