Author: Subject: tiny steering rack
Mr Whippy
posted on 8/9/14 at 12:11 PM Reply With Quote
tiny steering rack
Hi
I've been looking for a very small and light steering rack or steering box for my kids 1/2 scale landrover. I know there is miniture ones available for karts but there around £150! which is way too much
any ideas?
loggyboy
posted on 8/9/14 at 12:15 PM Reply With Quote
Quad bike? No idea what set up they use (obviously handle bars) but could be a start.
Mistral Motorsport
posted on 8/9/14 at 12:20 PM Reply With Quote
Smallest car one was on the Hillman Imp.
loggyboy
posted on 8/9/14 at 12:21 PM Reply With Quote
http://www.quads4kids.co.uk/product/791/goka-buggy-steering-rack
Mistral Motorsport
hkp57
posted on 8/9/14 at 12:50 PM Reply With Quote
A few years ago I built a mini sandrail buggy, I got hold of a Mk2 Escort rack where we took it apart cut it down and welded it back up.
Never had any issues with it for a buggy, I was looking for a better pic but dont have any to hand at work but you get the idea.
Once you take them apart the long straight shaft has plenty scopt to be cut down.
[Edited on 8/9/14 by hkp57]
Fleet
SKC Raptor R - Hayabusa
Toyota C-HR Hybrid Limited Edition
Honda VFR1200 CrossTourer
DCT
Marlin Roadster 1800
Mercedes Vito 116 Sport
Volvorsport
posted on 8/9/14 at 01:15 PM Reply With Quote
microcar.....
www.dbsmotorsport.co.uk
getting dirty under a bus
posted on 8/9/14 at 01:18 PM Reply With Quote
For a kids toy would a steering shaft with a pitman arm and a coupe drag links not be enough?
mcerd1
posted on 8/9/14 at 01:44 PM Reply With Quote
^^ that's what we had on the lawnmower based things my dad made for us - it worked well enough
Mr Whippy
posted on 8/9/14 at 02:00 PM Reply With Quote
Some helpful suggestions.
loggyboy, thanks but that quad rack may actually still be to big! 20cm long seems to be the limit I can accommodate
I currently have a simple pitman arm and drag links but the weight of the front with the batteries in it and some grippy offroad tyres are making the front quite heavy and the steering too heavy for my daughter to turn while the cars stationary. I have been looking at some steel cog sets that look a promising alternative.
posted on 8/9/14 at 03:51 PM Reply With Quote
I fabricated steering for my go-kart as shown below. Not as good as a proper steering rack, but with some effort you can get the steering angles to work and achieve some Ackerman effect as well. Easy to do with off the shelf parts including 4 off rod ends @ £2 each and a length of M6 threaded bar from Screwfix. The uprights are made from thick wall tube and angle, bolted though a formed U bracket.
ETA...re-reading your last post on steering effort, mine is relatively light, but then the front of the kart is light with skinny wheel chair wheels. It also uses MTB handlebars, which give plenty of leverage.
Maybe you could use the same design, but gear the steering column to a slave column with cogs or even a belt.
[Edited on 8/9/14 by nick205]
MikeR
Contributor
Posts 8600
Registered 25/5/02
Location Hinckley
Member Is Offline
Photo Archive Go!
Building: Slowcost since 2000, speeduino since 2020, Caterha
posted on 8/9/14 at 06:58 PM Reply With Quote
About to upgrade my sons 'lightning' plastic bin car. Plan is as follows
Link left and right wheel with solid rod between steering arms
At same point attatch bike chain
Fix bike small gear to steering shaft.
Put chain over gear
Hey presto (in theory)
SPYDER
posted on 8/9/14 at 10:25 PM Reply With Quote
Cinquecento rack is quite small IIRC.
andy350z
posted on 10/5/18 at 09:08 AM Reply With Quote
Put chain over gear
Sorry to resurrect an old thread.
Did you plan with a bike chain work Mike? I’m looking to upgrade the steering on my son’s swing bin car too. The bobbin and cable design doesn’t work very well.
