Author: Subject: kliktronic
Flick
posted on 26/9/14 at 12:14 AM Reply With Quote
kliktronic
Kliktronic electric gear change
Bought this secondhand a few months ago but change of plan so now for sale.
Full working order, I've tested it and it works exactly as it should.
Rod out of piston has very slight twist in it, not sure why but rod been slightly filed down on one side. Can't imagine why don't think it would make any difference, maybe just vibration noise or something. But works absolutely spot on.
New mounting bracket
Control box has cracking on base plate. Not big deal as its fully sealed inside. Could either leave as is, put line of silicone round or pull off base and make a new one.
Switches are included but have had it. Not expensive to replace if wants though.
Fitting instructions
Paddles from jag xf. Just paddles though with wires that I've soldered in. Soldering bit rough may want to redo but plenty strong and again tested and work fine. Don't have mounting plate for paddles as I was going to make one. Easy enoung I reckon out of piece of Ali.
All wiring included.
Cheap electric paddle shift kit for someone, just needs a bit of work/tarting up. Like I say fully tested and working with no problems.
£150 anyone?
marco
posted on 26/9/14 at 09:10 AM Reply With Quote
Very interested if it hasn't sold can you put up a picture or two of the damaged bits, does the box of tricks do up clutchless upshift and downshift? Ie cut the coils and blip the throttle?
Flick
posted on 26/9/14 at 11:25 AM Reply With Quote
Hi mate
no its just the electric solenoid gear change. You would need separate/additional items for part/full throttle ups and clutchless downs.
thanks matt
marco
posted on 26/9/14 at 11:36 AM Reply With Quote
Ok thanks, not for me then.
madrallysport
posted on 26/9/14 at 12:17 PM Reply With Quote
Flick u2u sent re shifter
UNDERSTEER is when you hit the wall with the front of the car.
OVERSTEER is when you hit the wall with the rear of the car.
HORSEPOWER is how fast you hit the wall.
TORQUE is how far you take the wall with you.
Flick
posted on 4/10/14 at 05:20 PM Reply With Quote
Slight amendment to listing and price, can't find fitting instructions or buttons. Also found shaft slight rubbing when turned..spoke to klik about this though. Still works fine.
Rod out of piston has very slight twist in it, not sure why but rod been slightly filed down on one side. Slight rubbing when shaft is one way, but turn it round, no problem. Spoke to kliktroni bout this and they said its fine, not uncommon, can be straightened in vice if really wanted. But to be honest, its fine as is so I haven't bothered.
New mounting bracket, no mounting holes drilled yet.
Switches are not include, but can be bought if required.
wires are labelled
Paddles from jag xf. Just paddles though with wires that I've soldered in. Don't have mounting plate for paddles as I was going to make one. Easy enoung I reckon out of piece of Ali.
£140 inc p&p
[Edited on 4/10/14 by Flick]
capri_big_jim
posted on 4/10/14 at 07:06 PM Reply With Quote
I sent you a PM about this and never got a reply. I presumed you had sold it.
Jim
Flick
posted on 4/10/14 at 09:09 PM Reply With Quote
Jim
My apologies, though I'd replied to everyone.
capri_big_jim
posted on 5/10/14 at 08:22 AM Reply With Quote
Pm sent.
Flick
posted on 5/10/14 at 09:16 AM Reply With Quote
Pm sent.
U2u replied to
capri_big_jim
posted on 5/10/14 at 10:12 AM Reply With Quote
PM sent. I will take it mate.
Jim
