Author: Subject: Full engine package
greavesy7
posted on 28/9/14 at 07:54 AM Reply With Quote
Full engine package
Looking to update my engine over the winter for a new challenge so I'm selling off my old parts
2.1 pinto with spec as follows
Lightened and balanced bottom end and fly wheel
Big valve head with race cam ( doesn't run too lumps so very drivable)
Vernier pulley
Burton alloy rocker cover
Shortened sump
Fire blade carbs on alloy manifold
Hi gear starter motor
£850
Type 9 gear box with low milage and short throw shifter
£170
richwill
posted on 28/9/14 at 07:27 PM Reply With Quote
What sort of power are you getting from the pinto. How many miles has it done?
greavesy7
posted on 28/9/14 at 07:34 PM Reply With Quote
I've not had it rolling roaded but it pulls very well, it has done about 2000 miles since it was built where is had new rings bearings and stem seals
richwill
posted on 28/9/14 at 07:51 PM Reply With Quote
I have a 2.0 pinto installed which has standard efi set up which gives 97 bhp at the wheels. I was looking for a simple increase in power for a winter upgrade but I'm not sure if this would do the trick.
greavesy7
posted on 28/9/14 at 08:40 PM Reply With Quote
Typically engines with this spec produce around 140-155 bhp at the flywheel
greavesy7
posted on 29/9/14 at 12:19 PM Reply With Quote
This package also comes with the zero manifold and exhaust silencer along with a bestec ignition
dbaz293672
posted on 5/10/14 at 09:14 PM Reply With Quote
U2u sent
greavesy7
posted on 6/10/14 at 08:41 PM Reply With Quote
Sold
