loughlin1
posted on 30/9/14 at 06:37 PM |
suspension brackets
Hi all
could you please tell me how many brackets needed for the haynes roadster
Slimy38
posted on 30/9/14 at 06:48 PM |
Two for each wishbone, sixteen in total.
You also need some narrower ones for the suspension, fronts need top and bottom, rears only need top (assuming Sierra based upright). Six in total.
loughlin1
posted on 30/9/14 at 07:57 PM |
Hey thanks for that I am working off the build your own sports car for as little as £250 and it says all the one size and 26 of them am i working off
the wrong book?
Slimy38
posted on 30/9/14 at 08:34 PM |
the wrong book?
The Haynes roadster comes from the 'build your own sports car on a budget', which uses a Sierra donor. The '...£250' book is
the original locost book and uses an Escort donor. It's not necessarily the wrong book, you just need to use the right donor to match. I
actually bought both, but I'm using a lot more info out of the Haynes roadster book.
[Edited on 30/9/14 by Slimy38]
